PSW505 Squeaking
idahovandal
idahovandal Posts: 1
edited August 2012 in Troubleshooting
I just purchased a psw505 from new egg for my new theater system and right out of the box its squeaking when ever the bass hits almost like something isn't tightend enough its pretty loud too it sounds like its comming from the back plate but I don't want to take anything off incase of voiding the warranty. I could return it ot new egg but was hoping it might be common or a setting I didn't get right.
Vandal
Post edited by idahovandal on
    EndersShadow Posts: 17,732
    edited July 2012
    Call newegg right away and discuss this with them. It shouldnt do that at all. If your not on carpet put a towel underneath it and see if it still squeaks. Make sure you dont have the gain all the way up. Thats about all the troubleshooting I would try.
  • Bass12
    Bass12 Posts: 3
    edited August 2012
    I bought my PSW505 a few days ago and I'm having the same problem as idahovandal. I bought mine from Amazon though.
  • zane77
    zane77 Posts: 1,696
    edited August 2012
    I have two of them and haaven't had any problems. I agree with EndersShadow and contact the seller right away
    Two Channel
  • tonyw
    tonyw Posts: 21
    edited August 2012
    Man the 373 positive eviews are starting to look kinda faked to me dammit! I just gota psw 505 off of amazon, mine doesn't squeak but it sounds like a wind storm when I play really low bass thru it! And don't take off the plate amp, just tighten up screws a lil, even if you could get plate off, there's no way to feel around on inside of the box, its cramped with baffles and such in there
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2012
    same here they work great
    zane77 wrote: »
  • samfraser
    samfraser Posts: 21
    edited August 2012
    Mine works great, but if it is squeaking, maybe something loose in the enclosure, or perhaps a bad voice coil?
    Yamaha RX-A710
    Monitor 70 Mains
    CS2 Center
    Monitor 40 Surrounds
    PSW505 Sub
  • whitecamaross
    whitecamaross Posts: 219
    edited August 2012
    samfraser wrote: »
    what he said...
  • whitecamaross
    edited August 2012
    just contact new egg and let them handle it.
  • Charles0511
    Charles0511 Posts: 1
    edited August 2012
    I had mines for less than 30 days, and it just start squeaking this morning. I'm bout to contact Amazon right now.
