speaker settings question
edited July 2012 in Speakers
my setup is,
Polk monitor70 (2)
Polk cs2
Polk psw505
Yamaha RX-V573BL
so right now on my receiver im using
0db for front speakers
0db for center speaker
-10db for sub
front/center speakers are set to small
keep going back and forth between 60 and 80 hz but i cant tell a difference.
distance is about 10-11 feet for all speakers.
right now the max i can turn up the volume is set to -16.5db, when watching a movie i turn the system up to around -20db and -23db.
just wondering what the difference is between raising the db on each speaker so i wouldnt need to turn the volume up as much vs's leaving the settings like they are?
Post edited by skuzzzzy on
Welcome!
    edited July 2012
    Makes no difference. Leave everything as is.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
    edited July 2012
    was just wondering if i was using right settings cause it seemed like i was turning the volume up too loud considering default max db is set to -16.5 and im only 3.5db from that at movie watching volume.
    edited July 2012
    The sub setting seems fairly low in my opinion. Normally thats the one channel most boost to +2 or 3. Set the front speakers and center to large and see if you like the sound better.
    edited July 2012
    yeah, sub too low.
    if you want more bass, raise the bass to xover to 80, or even 100. But you listen on pretty low volumes, at those levels the M70 are prorably not missing any power even when powered just by a receiver. If you turn the volume up though you will probably want the subwoofer to handle the LFE and cut the M70 at 80
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
    edited July 2012
    skuzzzzy wrote: »
    Try this; keep all speakers set to small. In the receiver, set mains and center to 40hz, surrounds to 70hz. Set your sub to 120hz LFE. I bet that gives your speakers and sub a nice blend. Keep your db ref at 0.
    Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
    Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
    edited July 2012
    You weren't happy with the YPAO calibration? Just curious b/c I keep reading that YPAO is inferior to Audyssey. And being that I'm using Audyssey, I enjoy reading complaints about YPAO. J/K. If I ever get around to upgrading it will probably be a Yammie due to my having a few good years of enjoyment from an old HTR series before ending up with Marantz a couple of years ago. Still a believer in the "natural sound" of Yammie receivers.
    Also, are you bi-wiring those 70s? Your avr has that feature if I'm not mistaken.
    Lastly....pics! Let's have a look at the bedroom HT.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
Welcome!
Welcome!
