poster frames
anyone here know where I can get metal poster frames for less than an arm and a leg? for the halibut, (ha ha ha) I went to a local frame shop.. they wanted close to $125 to frame a poster for me.. WTF? I'm in the wrong business that's for sure.. the poster only cost me about $30 so no way am i going to plunk down another $125 for a frame.
so any online places I should look. my poster is 38" tall by 26" wide.
thanks a bunch, Al
PolkFest 2012, who's going>?
Welcome!
    edited October 2003
    no idea, go to .......
    www.yahoo.com -- Click on Shopping
    Type in Metal Poster Frames, good luck, hope that helps.....search on EBay.......and MSN........and just basic search
    edited October 2003
    Try "Michaels" if you have one near by....or a crafts store. They usually have custom framing, as well as, DIY framing available. The DIY is often in generic lengths, but perhaps it will be exactly what you need.
    edited October 2003
    Go to the nearest theatre with a wonderbar and a good buzz. With any luck you'll get a set of back-lights too. With any luck you won't get any jewelry. Those bracelets realy hurt. On a more serious note any handy man with a mitre saw an alittle bit of know how could probably throw one together for 50$
    "It doesn't get any more serious than a Rhinocerus about to charge your ****."
    edited October 2003
    Check out your local "Hobby Lobby" if you have one in your area. They have every kind of frame and will even custom build for you.:D
    ††Polk-A-Nizer~~Ulrich††
    Nizer The Wizer
    "I can blast my Polks longer and they keep getting stronger!"
    edited October 2003
    Hey danger,
    I buy a lot of frames to display photographs and usually get the metal sectional frames from a company called Light Impressions that specializes in archival photo products...but they sell frames too. The website is www.lightimpressionsdirect.com
    Check out the Nielsen sectional frames. Style #11 is good for smaller stuff, but if you are using glass you might need to go with something a little sturdier and with a bigger slot (for glass, poster and backing material) like style 117 or 22...they cost more. For instance a black (or silver or grey) frame in your size would run you $15.12 for the pair of 36" lengths and $11.76 for the two 28" lengths and then a buck and a half for a frame kit (hardware). So you are talking like under 30 bucks plus shipping (obviously it pays to order in bulk).
    If you are in no hurry call them at 800 828 626 and tell them to send you a catalog. It shows all the colors etc.
    Woody
    system 1:
    Athena: AS-F1 mains, AS-C1 center, AS-B1 surrounds, AS-P400 sub, Yammie RXV-730, Rotel RB-976 driving front stage, Samsung BD3600 Blue Ray, Denon DVD2900 for sacd/cd , jbl n24awII on the deck, samsung 40" 1080p lcd
    system 2:
    XBox 360 Spherex 5.1 system, HK DVD38, Phillips CDC 926 CD changer, Phillips 32" LCD
    2 channel
    NAD 1600 pre, NAD 2400 THX amp, Phillips CDC 926, Linn extra speaks, crappy TT
    edited October 2003
    thanks guys.. some real good ideas to consider.. and i'm not in any hurry...
    I'll check into these and see what i can find.
    thanks, Al
Welcome!
Welcome!
