B&K 125.5 or125.7 owners
paymontana
paymontana Posts: 234
edited October 2003 in Electronics
I was just currious. My new amp was delivered half open by Fedex. Should there be 5 audio jacks or a remote with it. Every think else seemed to be in order. I was definatly and inttentionaly opened. LOVE that B&K sound!
"It doesn't get any more serious than a Rhinocerus about to charge your ****."
Post edited by paymontana on
  • polkatese
    polkatese Posts: 6,767
    edited October 2003
    nope, it's just the amp and manual. Have fun setting it up and congratulations!
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • paymontana
    edited October 2003
    Thank you Mr. Atese. All ready have it wired sounds dgreat even w/ my little yamaha. Still waiting on the denon 3803. When my funds recover I might looking for a 125.5 or .7 to biamp the whole system. I bet that would be one kick **** sound. Do you have yours plugged into your reciever so it come on automaticaly . I know they don't reccomend it. I was forced to put mine behind the rack to give it propper ventalation. Or is there another way to configure it. The mannual wasn't real clear on the daisy chain instructions.
    Thankyou
    CJ
  • polkatese
    edited October 2003
    pm,
    I use my 125.7 along with B&K Reference 50. How it works, as far as controlling it, is through 12v Trigger. I am not sure if 3803 comes with 12v Trigger, but that is the best way. If not, Radio Shack sells a trigger control using switched outlet on your receiver. The daisy chain basically allows you to control multiple power amps, when connected to a receiver/pre-amp equipped with trigger control. Each of the power amps has in and out trigger, so from one power amp to the next, you connect them using trigger cable (mini mono headphone plug), and *daisy chained* them together. Hope it helps.
  • mantis
    mantis Posts: 17,201
    edited October 2003
    Why not buy a preamp instead of a amp.
    I know you got a B7K amp.You can pick up a used B&K ref 30 for under 2 g's.Go for it and upgrade it down the road.B&K has the upgrade out already.
    Dan
    Dan
  • paymontana
    edited October 2003
    3803 just arrived. It does have a 12v trigger but it does not have a 3prong outlet. Looks like i'm going to the shack. Maybe I should have looked into the B&K prepro but I am on a budget.
    Thanks,
    CJ
