VSX-1021-K or VSX-94TXH
Danny_69
Which of these 2 receivers is best?
My friend gave me the 94txh and I already own the vsx1021
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-94TXH
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/VSX-1021-K/
Thanks for the help!
Post edited by Danny_69 on
The 94 is probably 4yrs but has more head pwr plus preouts for amp, the 1021 has no preouts. Depends how rough your friend was on the 94 and what gear you have....I would keep the 942-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yeah I found that out its 4 years old.
I was curious because every time I see the ELITE label I think it's legit haha
My current setup is
Pioneer VSX-1021-K
Pioneer SP-PK51FS 5 speakers
Polk Audio PSW505 (Subwoofer)
Only thing connected really is my PS3
Thanks for answering though txcoastal1 -
If you can hold onto that 94 its a nice unit....you never know2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Should I use it instead of the 1021?
The 94 will likely sound better than the 1021 and has preamp outputs. I'd say if the 94 has all the inputs and features you need I'd use it. If you let your AVR do video scaling the 1021 likely has a better scaling chip.
I would use the 94. Its a better avr IMO.
The vsx94txh is a much better AVR despite it's age. I loved that model.Dan
The one YOU think is best is all that really matters.If you can't hear a difference, don't waste your money.
