SDA Custom PCB's Round 2
gimpod
gimpod Posts: 1,793
edited August 2014 in For Sale (FS) Classifieds
These are bare boards (no components) and were designed to use bigger Caps & Resistors like Sonicap & Mills and work for the following SDA's with a single board crossover and a Pin/Blade IC cable.
SDA 2B (1987 Blade/Blade IC with single board crossover)
SDA 2B/CRS+ (Pin/Blade IC)
SDA 1C
SDA SRS 2 (1987 Pin/Blade IC with single board crossover)
SDA SRS 3.1TL
SDA SRS 2.3
SDA SRS 2.3TL
SDA SRS 1.2
SDA SRS 1.2TL
Now there are somethings you need to be aware of.
First: Mounting (This only affects the SDA SRS 1.2/TL and the CRS+).
Because of the size of the new boards (10" x 5 1/4" vs 5 3/4" x 4 1/4") the only place I can think of to mount them in the CRS+'s is on the inside top or bottom of the enclosure and extend the leads (P & R) to the big 16mH inductor.
Now that brings us to the SDA SRS 1.2's, I might suggest that you could mount the board on the crossover plate plug everything in and then slide the top in at an angle then move the whole assembly up so you can slip the bottom in and then bolt in place (it should be able to fit through the cabinet opening measuring 4-3/4" high by 14-3/16" wide) and if that doesn't work you could mount the bare crossover plate first then slide the assembled crossover through the hole for the PR and then bolt in place.
Second: Let me ensure you that these boards are electrically identical to the originals with two exceptions, there is no place for the 750pF Silver Mica bypass cap(C4) for C3 it's not needed with the newer/better cap's you can buy today and nobody uses it anyway also I added a jumper (J4) for the Non-TL 2.3's & 1.2's to make things a little easier along with the ability to use a 3 pin connector for the P and R wires if you want.
Ordering & Shipping:
  1. Cost $100.00 a Pair including shipping and PayPal fee.
  2. These boards will be for Club Polk members ONLY!.
  3. Payment will be by PayPal (NOT as a gift please) or USPS money order.
  4. Shipping will be by USPS 2-3 day Priority Mail.
  5. Just PM me your order and we'll go from there. Also once you put solder to these THEY ARE YOURS
If you want more info about the boards, schematics and what parts you'll need go check out www.gimpod.com.
Thank You ~ gimpod
P.S. Please excuse the pictures, With the boards being a shiny black there real hard to get a good picture of.
Top View
Bottom View
Post edited by gimpod on
«13
    VR3 Posts: 28,782
    edited July 2012
    These are some of the finest circuit boards I have seen before - buy with confidence! :)
  • gimpod
    gimpod Posts: 1,793
    edited July 2012
    Saturday bump,
  • DaveHo
    DaveHo Posts: 3,536
    edited July 2012
    Interested, but not sure if I have the skills to tackle this large of a project. Have solder before, but not extensively nor for quite some time. Anybody out there who can help me out? This would be for a pair of 1C's.
    -Dave
  • Dawgfish
    Dawgfish Posts: 2,554
    edited July 2012
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited July 2012
    Tony,
    Thanks again for your efforts on this. MO on its way via the Pony Express. Let me know when you receive it.
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • GlennDog
    GlennDog Posts: 3,121
    edited July 2012
    DaveHo wrote: »
    -Dave
    I'm in the same boat. Work needed would be for 2Bs
    Thanks,
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • WastelandWand'r
    edited July 2012
    Dave and Glenn,
    If you have ever touched a soldering iron/pen then you have the skill set. People speak in hushed/disapproving tones whenever I
    decide to go beyond changing the oil in my car. Things like locating the fuse panel have stumped me before so I am no expert on things mechanical or electrical and I managed to do several of these. Desolder, resolder, remount in the speaker. Not a whole lot to it.
    Tony has made this super easy with the expanded size and his website. Plan on the first one taking a while and the second one going much quicker.
    Get them and get at it.
    Nathan
    Home Rig
    Polk 1000p Center
    OPPO BDP-93
    Squeezebox
    Sales Rating #1!!
  • gimpod
    gimpod Posts: 1,793
    edited July 2012
    Nathan thanks for the plug.
    All orders have shipped.
  • gimpod
    gimpod Posts: 1,793
    edited July 2012
    bump.
  • gimpod
    gimpod Posts: 1,793
    edited August 2012
    Bumpity Bump
  • factorz
    factorz Posts: 353
    edited August 2012
    Gimpod if I wanted to change out the stock standoff's to use with these boards what do you recommend and from where?
  • gimpod
    gimpod Posts: 1,793
    edited August 2012
    factorz wrote: »
    You'll need to change the stock mounting hardware as the mounting holes on the new boards are for 8-32 screws not 6-32, Here's a link to a page that has links to all the nylon mounting hardware www.gimpod.com/parts.html while your there check out the rest of the site for info on your SDA's
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2012
    Has any one built them up yet? Pictures are cool. :razz:
  • gimpod
    gimpod Posts: 1,793
    edited August 2012
    Bump, PolkieMan get your search on. :razz:
  • madmax
    madmax Posts: 12,434
    edited August 2012
    Hey gimpod, do you have any more of these?
    madmax
    Vinyl, the final frontier...
  • gimpod
    gimpod Posts: 1,793
    edited August 2012
    Yes I do! Info coming via PM.
    VR3 Posts: 28,782
    edited August 2012
    Here is a GIMPOD board populated (Except for the P/R connections)
    Buy these folks... :)
  • madmax
    edited August 2012
    Got my boards today, very nice! Now I have to figure out what to populate with...
    VR3 Posts: 28,782
    edited August 2012
    Clarity Cap and Mox resistors.. *wink* *wink*
  • madmax
    edited August 2012
    Hey VR3, wanna build them?
    VR3 Posts: 28,782
    edited August 2012
    Ill build annnything! heheh :)
    Shoot me an email Vr3Mods@GMail.com
  • madmax
    edited August 2012
    I'll shoot you an email Monday morning. I'm just getting back into the 1.2's and while I could build these myself I'd rather have a professional audiophile such as yourself put them together.
    madmax
  • gimpod
    gimpod Posts: 1,793
    edited August 2012
    madmax wrote: »
    Sonicap Gen 1's & 12 Watt Mill's (after all that what the boards were designed for:wink:)
    VR3 wrote: »
    Pusher. :wink::razz:
    [video=youtube_share;rpoEmlxUPeQ]http://youtu.be/rpoEmlxUPeQ[/video]
  • madmax
    edited August 2012
    Awesomeness!
    madmax
    VR3 Posts: 28,782
    edited August 2012
    Hehe... There is no denying the Clarity/Mundorf combo sounds incredible :)
    Would love to help a fellow long standing polkie out :)
  • gimpod
    gimpod Posts: 1,793
    edited September 2012
    Still have them available bump.
  • gimpod
    gimpod Posts: 1,793
    8 day bump.
    VR3 Posts: 28,782
    Tony is awesome... buy his boards...
  • gimpod
    gimpod Posts: 1,793
    And while your at it have VR3 build them up for you.
    One shameless plug deserves another. :redface: Thanks Trey.
  • gimpod
    gimpod Posts: 1,793
    bumpity, bumpity, bump, there that should on the front page for at least a day or two. :rolleyes:
