psw111 back plate need help
sagasa
sagasa Posts: 127
edited June 2012 in Troubleshooting
Hi, need some instruction, How do i remove the back plate do i just unscrew
and pry it with a screw driver, Im afraid that i might scratch it.
Thanks for any info,
A newbie.
Front: Tekton Pendragon
Center: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2
Post edited by sagasa on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited June 2012
    Well I think unscrewing it could help.....
    Not sure I would use a screw driver to pry it out but that's just me.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • cr136124
    cr136124 Posts: 186
    edited June 2012
    Unfortunately in some cases that is the only way to do it (pry it with a screw driver), but you can mask it - not only the screw driver tip, but also the back plate face in the area that you will be working at.
    Just take your time (no rush) and try to pry it at different places in order to loose it a bit.
    Good luck!
  • sagasa
    sagasa Posts: 127
    edited June 2012
    Thanks for info i was able to remove it by a little shaking and prying after unscrewing it. this thing just quit working so iwill
    be sending it to service center.
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
  • cr136124
    cr136124 Posts: 186
    edited June 2012
    Glad to hear that you managed to remove it. Yep, if you are having issues constantly with this unit, then it might be better to contact Polk Customer Service.
    Good luck!
