New Subwoofer Recommendation Needed
wowbagger1234
wowbagger1234 Posts: 5
edited July 2012 in Troubleshooting
I'm currently using LSi25s in 9.2 setup, but when I watch movies I occasionally hear the subs crapping out. I've looked at the DSW Micropro series, but the reviews are so-so. Are they worth the upgrade from the powered subs inside the Lsi25s?
How does the Polk Audio DSW PRO 500 series compare to the LSi25 subs and the Micropro series? At 300 bucks on Amazon, it's much closer to my pricerange. Would I notice a difference from the LSi 25 series and would it be worth the investment?
Post edited by wowbagger1234 on
  • jon s
    jon s Posts: 905
    edited June 2012
    How big is the room? If the room is small, maybe... But a sub that small won't do much over the LSi25s if any....
  • PolkieMan
    PolkieMan Posts: 2,446
    edited June 2012
    I heard Amazon was going to start charging sales tax tomorrow, July 1, 2012.
    I have two PSW-505 but I only use them in action movies as my 2.3tls are enough for anything else. Having two means I don't turn then up much so they never sound strained or boomy Thanks.
  • pietro944
    pietro944 Posts: 720
    edited June 2012
    PolkieMan wrote: »
    Everywhere?.....or just certain states
    txcoastal1 Posts: 13,499
    edited June 2012
    pietro944 wrote: »
    Probably just TX and any where else they have whse's, Amazon and Tiger direct both opened distribution in TX
  • wowbagger1234
    edited July 2012
    it's a fairly small room. 12x12.
  • arny
    arny Posts: 37
    edited July 2012
    The LSI 25 specs say that the so-called subwoofer is a 10" driver. Subwoofers are all about moving air, which is facilitated by a driver with a large diameter (12-18") and long linear stroke (at least an inch or 25 mm). 10" drivers are inherently limited in this regard.
    A room that is 12 x 12 with a typical ceiling height (8-10 feet) is a relatively small room. Small rooms introduce a build-up of bass starting at a relatively high frequency, often above 50 Hz. Recommendations for subwoofers therefore need to be less aggressive than they would be for a room that is say, 2-3 times as large.
    The safest approach is to evaluate your system's current performance by objective means, which is relatively easy and economical these days. I suspect that your next subwoofer would need to be in the $600-1200 range to show a clear advantage over what you already have.
  • deronb1
    deronb1 Posts: 5,021
    edited July 2012
    Def Tech Supercube II. 8" with a ton of power.
  • jon s
    jon s Posts: 905
    edited July 2012
    I have the Def Tech Supercube 6000... It sucks for a $1000 sub. A 9" driver (with two passive 9" radiators) just don't move a lot of air. The SPL between 20-30Hz is about 15-20dB below the SPL between 30-40Hz. The -3dB point is about 29-30Hz and it rolls off above 100Hz at the top end. If your primary speakers don't go too low, you will have a mid-bass suckout. I preferred my older Polk PSW650 (which died unfortunately) which had a better bass balance (but still nothing below 30Hz)...
