How far does one 18X32 Sheet of Dynamat Extreme Go?
GlennDog
GlennDog Posts: 3,121
edited June 2012 in Vintage Speakers
I want to cover the SRS 2s and my 2Bs. The baskets on the PR and the MW will be done. Does anything else need Dynamatting? (besides the baskets)
Amazon price $29.05 w/ free ship a good deal?
TY,
G
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
Post edited by GlennDog on
  • gimpod
    gimpod Posts: 1,793
    edited June 2012
    I'd say yes one sheet is more than enough. Just the baskets.
    Toolfan66 Posts: 17,335
    edited June 2012
    More then enough...
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • GlennDog
    edited June 2012
    Cool . . . Thanks Guys!
    Have an excellent weekend!!
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
  • teekay0007
    teekay0007 Posts: 2,289
    edited June 2012
    GlennDog wrote: »
    TY,
    G
    I was wondering the same thing - how much was needed to do my SDA-2Bs and Monitor 10Bs. So, I guess, if you're covered for those two pairs, I should be set also. :cool: If there's any left over, I read in a few threads where guys suggested using the Dynamat Xtreme in layers - but I don't know if that makes any real difference. Maybe I could use some extras for my Monitor 5jrs or RT5s? Just don't know if it's worth it there. :confused:
    As far as price is concerned, last week when I was checking around, the best price I found for an 18x32 (4 Sq Ft) sheet was right around $25 shipped by a few sellers on Ebay with excellent feedback. The only difference I could tell from what their listings included to the contents of a Dynamat Xtreme Wedge Pak was that they apparently had just cut 18x32 sheets from bulk sheets and put them in generic packaging.
  • teekay0007
    edited June 2012
    Just ordered a Dynamat Xtreme Wedge Pak 18x32 - 4 sqft - sheet in manufacturer's packaging on Ebay shipped for $24.50!
    Couple more left: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360467543141
    Not affiliated.
