Considering a Adcom 555, speaker protection a concern?
downhiller2010
downhiller2010 Posts: 32
edited June 2012 in Vintage Speakers
I recently bought some monitor 10's and have decided they need more power than the 65RMS they get from my marantz 2245. I wanted a marantz 250, but the cost is prohibitive so I have been looking at Adcom GFA-555's since they are relatively inexpensive and I will never have to worry about headroom again. BUT....do I need to be worried about speaker protection? My monitor 10's do have polyswitches but should I add fuses temporaroly? or add a speaker protection circuit to the 555?
Post edited by downhiller2010 on
  • xoaphexox
    xoaphexox Posts: 246
    edited June 2012
    If the 555 is in good health I'd say you have nothing to worry about.
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
  • gimpod
    gimpod Posts: 1,793
    edited June 2012
    xoaphexox wrote: »
    +1, There is only one good speaker protection circuit out there "YOU" just don't be cranking the crap out of the eviction control knob.
    A word on speaker protection circuits, None of them are %100 perfect or will protect against all the possible things that can go wrong with a amp, besides it's just another circuit to get between you and your music.
  • Schurkey
    Schurkey Posts: 2,104
    edited June 2012
    gimpod wrote: »
    Priceless. Thanks for that.
    gimpod wrote: »
    Yup.
    pitdogg2 Posts: 25,692
    edited June 2012
    gimpod wrote: »
    that is signature material right there folks
