What projector screens are you guys using?
polkfarmboy
polkfarmboy Posts: 5,703
edited June 2012 in The Clubhouse
Never hear alot of talk about projector screens here and wondered what screen you guys are using?
I currently have a little 90" for goofing around in my BD room. I bought it for $90 but then checked amazon and its shot back up to$200 so that was a good score. For my main theater I use a HC grey fixed frame thats a 110" and its a nice snap on screen that dont sag like the one in my bd room eventually will. I would like to go the whole hog in a 235:1 with anamorphic lens for true cinema experience some day soon
Post edited by polkfarmboy on
  • evhudsons
    evhudsons Posts: 1,176
    edited June 2012
    +1 gain white elite manual pulldown screen 150inches diagonal.
    It was cheap but works very well. The wall worked great too, but a screen makes it exponentially better.
    Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
  • polkfarmboy
    edited June 2012
    I used to have that exact same screen in the 150" too. The thing was a monster but the bottom bar had unevenly been fastened to the material causing a wave that was noticeable when the camera panned. Appart from that I loved the color and playing ps3 games on it and it only cost me $200 shipped at the time. The price is way higher now
  • jaritta
    jaritta Posts: 277
    edited June 2012
    Screen Innovations Performance series 1.1 gain screen. It is fantastic, great build quality. I also have seen the elite screens 4k AT material it is great, not quite as good build quality as the screen Innovations but still not bad
    Harman kardon signature 2.1 amp
    Denon 3312
    Epson 8700ub
    Chief mount
    Screen Innovations Performance Series 110in
    Kef q 500 (RL)
    Kef q 200 (C)
    Kef q 800 (Rear RL)
    REL T7 (SUB)
    mx 450 remote
    Sonos-Amp, Connect, Play5
  • evhudsons
    edited June 2012
    yeah, there is a little bit of material is coming loose on my bottom too but hasn't caused a ripple yet. I got mine under $200 shipped as well. Many online stores say the shipping is free until they see how big it is. I found mine at gpscheap.com. I have no idea what gps has to do with the projector screens but they had it and honored the price and shipping.
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2012
    126" Carada criterion screen, paired up with JVC RS10. Screen is 1.4 gain brillant white .
  • evhudsons
    edited June 2012
    by the way pfb, thanks for the leads on projectors. Now my head is swimming with specs and such. I think I'll be making a decision sometime soon. As soon as I find a projector that I think is perfect, it's listed as having too much lag, or too noisy, or too much ghosting, whatever. But, I have a feeling anyone of them would be better than my older sharp projector which still works quite well.
  • jon s
    jon s Posts: 905
    edited June 2012
    I have a fixed frame Stewart Filmscreen StudioTek 130 that is 108" wide. Gain is supposed to be 1.3 but the screen is microperforated so the gain is down by 10%.
    Unfortunately, my original setup was a NEC CRT which was about 150lbs. The aspect ratio of the screen was set at 1.85 (which is the native for most movies back then). Now when I watch movies, there is a small 2-3" black border on each side since most films are set for 16:9 or 1.78 now. I upgraded to a Marantz VP12S3 which was 1280x720 but later changed it to a JVC RS-1. Have had no regrets since then.
    My setup consists of an Onkyo TX-NR906 AV receiver, Pioneer BDP-05FD Elite Blu-ray player, a Denon DVD-3930 DVD player as sources. The speakers in the front are Polk RT55is (sometimes I use a pair of Sony SS-M9s for the LR). The surrounds are all HK Citation speakers.
    I also have a DarbeeVision Darblet inline with the projector. Anyone with a front projector or a large flat panel screen should invest in one. This is an image detailer. I don't understand how it works but it enhances detail in the image without adding any artifacts or edge enhancement. This box costs $270 and is worth every cent.
  • Zeros
    Zeros Posts: 940
    edited June 2012
    I use a cheap motorized 108" screen from monoprice since I have it hidden in the ceiling of my home theater room. It's OK, but there is some curling on the edges, which can be annoying. I bought it back before they offered the motorized, tensioned screens that they have now.
  • polkfarmboy
    edited June 2012
    Hey jons
    Does that thing really work?
    I have an epson 5010 arriving on Monday and it has a thing called super resolution built in that I have yet to see. That little box sounds very interesting so I may have to try one out with the super resolution feature to see if there is a further improvement.
  • B Run
    B Run Posts: 1,888
    edited June 2012
    That Darbee thing is blowing my mind right now, does it really work like it claims?
  • polkfarmboy
    edited June 2012
    I'm watching a video on it right now about the history behind it with the creator. He started this in the 70's but left it he then goes on about he invented the universal remote and owns universal electronics
    http://www.engineeringtv.com/video/DarbeeVision-DVP-History
  • B Run
    B Run Posts: 1,888
    edited June 2012
    I just keep playing with the little slider bar on this page: http://darbeevision.com/gallery
  • Sherardp
    edited June 2012
    Reviews on the Darbee are very positive on AVS. I ordered one, thanks for sharing.
  • B Run
    B Run Posts: 1,888
    edited June 2012
    Sherardp wrote: »
    Interested to hear your thoughts when you get it. Oh and by the way thanks for the heads up on the Sony bdp-s790! I got it in yesterday and am really impressed with its performance.
  • polkfarmboy
    edited June 2012
    B Run wrote: »
    Does the sony convert to 235 in 3D?
  • B Run
    B Run Posts: 1,888
    edited June 2012
    Honestly man i've had a 3dtv, 3d avr and 3d bluray player for over a year and still have ordered the damn glasses yet so i have no idea haha.
  • Sherardp
    edited June 2012
    B Run wrote: »
    I will definitely share my thoughts B Run. Congrats on the Sony S790. I love mine also. I tried everything under the sun and it works very well. Not sure if the dual core CPU helps much, but with networking it is extremely fast. From finding files to playback, streaming is really good. BD playback/audio is superb, with a very nice and sharp image. I'm curious to see what the Darbee adds to the equation.
    billbillw Posts: 8,078
    edited June 2012
    I'm using a Visual Apex fixed 100" 16:9 screen. Very nice quality for the price. Its a 1.1 cinema white screen.
  • polkfarmboy
    edited June 2012
    Those VA screens look really nice with that big thick border round them
    I just bought an elite screens model this morning. Thinking back to that 150" pull down I used to have I loved the bright color pop it gave me. The model I bought was a 235:1 166 inch monster and I can add a panamorph 480 lens later on and just overshoot it for now with the 5010. Most 3D movies are 16:9 so I can just move the pj closer to fill it and still have a big bright 3D picture
  • mantis
    mantis Posts: 17,632
    edited June 2012
    I've been hanging screens for many years and by far the overall best on the market is Stewart. They make the Industry standard which all others try and follow. They also cost the most but you get what you pay for here.
    Bang for the buck I like the Dragon Fly screens which are cost effective and have little hot spotting especially for the money.
    I've done a few Black diamonds and I was unimpressed especially for the cost. They are not in Stewarts league yet try and claim prices close to them. I'd rather have a Da-lite which is a nice alternative. Another would be Draper.
    You really can't go wrong with the top 3 in Stewart , Da-lite or Draper. All others follow far behind. It's also a matter of money vs quality. Good screen are not cheap , cheap screen are well cheap but can fit a budget and still do a nice job.
    I've seen the paint on wall screen and it's ok at best. Color never seemed quite right and if you don' sand your wall perfectly , you see all your mistakes. That sucked in one house I saw this.
    Dan
  • polkfarmboy
    edited June 2012
    I saw a review and the closest screen to match the accuracy of the stewart was the cheap elite material so thats why I chose that. For me it gives me everything I need without costing as much as a car. If you ask me stewart is way over priced even though its one of the best. I though the joe kane screens were better than stewart?
  • evhudsons
    edited June 2012
    One thing I like about my cheap Elite is that it has no sweet spot for watching. Friends can be outside smoking and looking through from the side can see it perfectly. No hotspots. That was one thing that turned me off about lcd's and rear projection, only those seated in the right spot could see the picture well.
    I did see online on youtube a stewart screen with one of the projector reviews. I could tell right away that image was popping out like nothing my elite will do. But, $$$$
