Audyssey XT32 Subwoofer Sweep
wingnut4772
wingnut4772 Posts: 7,519
I finally got my Integra DHC 80.3 today. I correctly set it for 2 subs ( I'm using
four subs, 2 on each sub output) and began running the full MultiEQ XT32 setup. I calibrated each set to 75 db as directed and began the sweeps. On the first sweep, Audyssey pinged both sets of subs but only pinged the first set on the remaining 7 sweeps. Is this right? Doesn't seem so. Any ideas?
TIA
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
  • mantis
    mantis Posts: 17,588
    edited June 2012
    Re check your settings , that doesn't seem right. I've set up many Integra Pre's and Receivers with dual sub outs and it tests both subs each time.
    Make sure you are connected to the internet and do a software update.
    Dan
  • wingnut4772
    edited June 2012
    Thats the first thing I did - the software update that is. Internet connection went without a hitch.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • mantis
    edited June 2012
    I should be doing one next week , I'll report back on my findings. I don't remember it not testing both subs each sweep , I would have noticed that. In theory it has to test all channels or how could it accuracy eq the room?
    Dan
  • wingnut4772
    edited June 2012
    I figured it out. I was mistaken. I thought it pinged the subs separately. It pings all at once. :)
    I have been listening and I think I prefer Audyssey off. Not sure yet.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2012
    You prefer the pre with xt32 off or just the subs?
  • wingnut4772
    edited June 2012
    With XT32 off. It's a tad bright to me I think. Not sure. Still undergoing extensive scientific testing. :p My subs sound good either way but they have about 6db more under 20hz without the EQ for some reason.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • mantis
    edited June 2012
    The 80.3 has the ability to test each sub separately. It's one of the features I love about Integra.
    Dan
  • wingnut4772
    edited June 2012
    It does do that. Ill keep playing with it.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • wingnut4772
    edited June 2012
    Well after much harassment over at Ask Audyssey it finally came down to a bad mic. Luckily I still had the old one lying
    around and now it sounds fan -bleepin'-tastic. Now I can finally hear what everyone was blathering about. At least for movies
    so far....
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • polkfarmboy
    edited June 2012
    Thats good that its all sorted out and I must say your impressions had me shocked regarding such a highly praised room correction system. I hope you enjoy it and its cures the upgrade bug for a couple of years
  • wingnut4772
    edited June 2012
    I know! I was insanely disappointed after all the glowing reports and the $2500 processor. I am glad it's fixed. Having said that....I am not so sure about the Dynamic EQ...will probably leave that off.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • mantis
    edited June 2012
    It's a badass preamp and I really like everything about it. I'm eagerly waiting on the 80.4 which should hit the store anytime now.
    Dan
  • wingnut4772
    edited June 2012
    This thing is really breaking in. Sounds very sweet. I am now a believer :D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
