woofer blowing fuses
louis1965
louis1965 Posts: 2
edited May 2012 in Troubleshooting
blowing fuses
I have a polk sub woofer madol LR106476 that have worked fine for 4 years and all of a sudden stopped working,i opened it up today, and found a blown fuse,i replaced the fuse with a 1.5 amp i cant read the amp size for sure but looks like a 1.5. anyway with the new fuse it blows as soon as i plug it in,the speaker makes a humming noise and the fuse blew and only did it once two more fuses and it blows right away. any ideas?
Post edited by louis1965 on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited May 2012
    Hello Louis,
    Thanks for posting on Polk's forum. In all likelihood there is a problem with the subwoofer's amplifier and it will have to be repaired. It would be best to contact Polk's customer service department at 1-800-377-7655 or send them an email at polkcs@polkaudio.com. They'll help you out.
    Regards, Ken
