LSi & How far apart?
wrxmy02
wrxmy02 Posts: 92
edited October 2003 in Speakers
Just wondering is there a sweet spot for the LSI7 on how far apart they should be
or is more of your room/sitting setting?
Front: LSI7
Center: LSIC
Surrounds: LSI7
SVS PB2-ISD SUB [MONOLITH!]
ATI 1805 Amp
Post edited by wrxmy02 on
  • polkatese
    polkatese Posts: 6,767
    edited October 2003
    I don't think there is hard and fast rule on this, experimentation is the only way to pinpoint the sweet spot, I am assuming this is for your main?
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • mantis
    mantis Posts: 17,629
    edited October 2003
    Basic rule,
    whatever the distance the speakers are apart from each other,thats the distance to sit away from and visa versa.Equal triangle.
    Sometimes I perfer the speakers slighty wider then distance to seating.
    Thats only the beginning to setting up main speakers...theres more
    Dan
    Dan
  • steveinaz
    steveinaz Posts: 19,546
    edited October 2003
    Because I have a very wide entertainment center, my speakers are about 12' apart, so I use about 1 1/2 inches of toe-in on each.
