What is BEST "Bang for the BucK" led tv under a grand?
dee1949
...asking for a friend who is 80 something. 50" is a Good size. Any input will be of help. No need for 3D.
Post edited by dee1949 on
LG 47LS5700 47-inch 1080p 120 Hz LED-LCD HDTV with smart TV at Amazon now $949.00
I suggest Plasma , you get a better deal and a better more realistic picture. Check out Panasonic Offerings in the S series.Dan
For a grand you could score a 55" ... TCP55ST30.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Totally agree with mantis and falconcry72. Plasma is WAY better route to go. But you asked for LED
How is the burnin issue these days on plasma tv's?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
If your still looking for LED. Tiger Direct has a 55'' ( LG 55LVL4400 55 Class LED HDTV ) refurb with warrenty $800. Panny Plasma still the better option IMO.
Are you going to show the same picture on it 24/7?
Otherwise, not much burn-in, at least not on my Panasonic. If the TV will be in the brightly lit room, LCD/LED panel is most likely a better solution. Otherwise, go with the plasma (Panasonic and Samsung will give better picture quality).
Oh yeah, not sure about the quality but $/size is most likely the new Sharp LCD.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
