Garage sale score
ravaneli
ravaneli Posts: 530
edited May 2012 in Speakers
I made a spontaneous purchase today. I accidentally saw this guy and offered 100 bucks to the owner. He said REALLY? FOR THAT THING? I immediately realized he had no clue what that was but didn't wana back out.
It is B&K EX-442 Sonata dual channel amp. That's all I know, has no information, no manual, not even a power cord. I don't even know if it works, but looks in great shape, despite a couple of scratches on the edge of the front plate. Been looking for a good dual channel amp for a while and took a risk on this guy.
I have a few questions now, because this is my first amp. Can I use regular RCA cables to connect my Marantz outs to this? I don't have anything else and I want to try it.
Also, Can I use the power cord from my computer? Looks the same. This amp says 900W consumption on the label though. Not sure my PC cord is up to that.
And lastly, if it doesn't work, how much would the average repair run in Chicago? In worst case I am out a hundred bucks.
BlueFox wrote: »
I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
But as in all things your perception is your reality.
Post edited by ravaneli on
  • zane77
    zane77 Posts: 1,696
    edited April 2012
    You can use regular RCA's, but some name brand cables may sound better, and your computer powercord will work although some people believe that better power cords improves sound just like better interconnecting cables.
    Two Channel
  • ravaneli
    ravaneli Posts: 530
    edited April 2012
    Scratch that. Left channel does not work. The guy agreed that I return it (he's kind of a friend and inherited that amp with a bunch of other equipment when he bought the house) but I would like to fix it if it's cheap. The right channel sounds great and the amp seems in great shape
    Can anyone recommend me a Chicago amp repair service? Doesn't have to be a reputable dealer, anyone who can fix them is good for me. Also, what would that run?
    BlueFox wrote: »
  • falconcry72
    falconcry72 Posts: 3,580
    edited April 2012
    Cool amp!:biggrin: Looks like it was made from '85 - '94, it's rated at 200 WPC @ 8ohms, 350 WPC @ 4ohms, it's a dual mono design, and it retailed for 1100 bucks.
    I would definitely try to get it fixed. It may just need a fuse or some soldering; it's worth taking a look anyway. Open it up and see if you can see any obvious problems in the path of the channel that doesn't work.
  • ravaneli
    ravaneli Posts: 530
    edited April 2012
    the other channels sounds amazing. i will definitely try to fix it. Actually if someone can reservice it to replace caps or whatever.. i would invest in that too.
    BlueFox wrote: »
  • falconcry72
    edited April 2012
    ravaneli wrote: »
    ...if someone can reservice it to replace caps or whatever.. i would invest in that too.
    Good call. Congrats on the snag, and good luck on the fix!:biggrin:
  • transmaster
    transmaster Posts: 428
    edited April 2012
    Wow what a steal even with a bad channel. I found another one of these amp's for sale else where and they want $500 dollars for it
    Radio Station W7ITC
  • Monster Jam
    Monster Jam Posts: 919
    edited April 2012
    Keep it for the money you paid ($100). Its a no brainer. My local electronics shop would fix it for between $50-$100. Killer deal.
    Do you hear that buzzing noise? :confused:
  • ravaneli
    ravaneli Posts: 530
    edited April 2012
    can anyone recommend a good repair shop around chicago?
    OK here is what I did, and you let me know if I f#kked it up myself. When I first powered it there was no easy way to test it without rewiring the way speakers were connected. But I had a pioneer elite subwoofer that I am trying to sell (auto) lying right there. So I got a 'brilliant' idea - use the amp to power the subwoofer and use the subwoofer for home theater instead of selling it!
    So I connect the sub preout from the Marantz to the BK amp, and use only one of the channels to the subwoofer. However I forgot that the sub is 2 Ohm :( Anyway, I played some music and the sub had something like pulse, i could feel it with my finger, but didn't really make any noise.. So I disconnect everything and tried it with speakers the right way. But now the channel that I had used to power the sub was not working. Did I f3kk it up myself?? All the fuses look good, and I didn't really go more than mid volume.. not even that. However there is no more even 'pulse' coming up from that channel.. not even when you touch the woofer of a speaker, and there was definitely a pulse before..
    BlueFox wrote: »
  • Geoff4rfc
    Geoff4rfc Posts: 2,824
    edited April 2012
    Congrats on your amp deal. Isn't your sub a powered sub? It would have it's own amp. The sub preout from your receiver is designed for your sub and not an amp.
    The amp is designed to be connected with to your receivers speaker preouts, providing your speakers don't already have amps.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • ravaneli
    ravaneli Posts: 530
    edited April 2012
    The pioneer that I used for the test was passive, from my car.., that's why it was 2 ohm.
    Come on Chicagoans... where do u fix your amps?
    BlueFox wrote: »
  • transmaster
    edited April 2012
    I don't know about this outfit maybe somebody does but they do look like a place to take you amp to in Chicago
    http://www.soundsclassic.com/
    Radio Station W7ITC
  • ravaneli
    ravaneli Posts: 530
    edited April 2012
    hmm, not that close, but I will give them a call to check them out. Thanks!
    BlueFox wrote: »
  • newrival
    newrival Posts: 2,017
    edited April 2012
    Hey, take it to deltronics. It's in downers grove, i believe. Not terribly far from you. Just down 355 and it's right off the toll way.
    I've got an amp there right now, and they've done a few pieces for me at a fair price.
  • ravaneli
    ravaneli Posts: 530
    edited May 2012
    Found a russian fellow who inspected it for free and said it will cost me 80 to fix it and another 70 if I want to replace a few caps and resistors. This thing is 25 years old.. I think I am gona go for both. Cant wait to test it.
    BlueFox wrote: »
  • ravaneli
    ravaneli Posts: 530
    edited May 2012
    Picked it up today. Rewired my A7 once again and did two hours of listening to the same old songs I use for testing. It was 2.0 using my Marantz SR5006 for receiver and HTPC was hooked to the Marantz with HDMI.
    As much as I would like to praise my new purchase, I was left rather underwhelmed. It sounded super clear. I have a huge living room with those high ceilings and during the piano intro into some songs the fidelity was incredible. Like a piano in my room! Those A7s play the piano really good! Here is the thing - my Marantz already played the same songs super clean! I could not find any audible difference in audio quality! Not even in loudness! It was NOT louder than my Marantz, although outweighing it by some 15 pounds and if you compare the amp sections only probably more than twice the weight of the Marantz amp. Nonetheless I did not notice some extra power. Bass was just as powerful to me as well. Perhaps slightly better separation of the drum beats, but I am really not sure. Even if there is difference it is too close for me to call. I don't know if my Marantz is too good, or the B&K is just from another day.
    But let me leave on a positive note. I did not intend to listen to music for two hours. I just practiced my BH loop and let it play in the background very loud (-6db). Eventually i was breathless and drowning in sweat and discontinued my BH improvement and went to check the amp. It was barely even warm. Room temperature on the entire case! My Marantz however, even though used only for processing, was almost concerningly hot. Actually I have been concerning about that for a while, perhaps someone can tip me on what I could be doing wrong.
    But here is the kicker: I have never before done two hours of listening to the A7s straight! They are fatiguing speakers. They were fatiguing with my Pio 521, Pio 1021, and Marantz 5006. But I did not experience fatigue this time, with the exact same (no EQ of any kind) settings. I did not find the A7s warmer sounding while listening, but they must be. The A7s are great for HT, but after even 30 mins of music I usally want to submerge my head on a bucket of cold water. I am pretty sure in the result but don't understand why I couldn't detect the warmness when I was trying. Oh well..
    BlueFox wrote: »
    F1nut Posts: 51,739
    edited May 2012
    Kinda boring here tonight, decided to read thru this one. For starters, you just got it back from the shop with new caps. They need to burn in. You are using an AVR as a pre amp for 2 channel music, never gonna get what that amp or any amp is capable of that way. Anyway, leave the amp in your rig for say at least two weeks (caps should be cooked by then) and then take it out. See if you don't hear the difference.
  • Drenis
    Drenis Posts: 2,871
    edited May 2012
    ravaneli wrote: »
    While using it as a pre-amp, did you remember to turn off the internal amplifiers? This is sometimes referred to as "Speaker A/B, etc...". My Elite AVR is room temp warm when it was used as a processor and internal amps turned off. On, and it's a whole different story.
  • ravaneli
    ravaneli Posts: 530
    edited May 2012
    I don't even know what you are referring to. I went through the Marantz menu and I don't see how I can turn the amp section off. I would expect it to be off if I don't use it anyway..
    BlueFox wrote: »
  • ravaneli
    ravaneli Posts: 530
    edited May 2012
    last night I did another stupid thing in a whim. I bought this just to check it out: Behringer EP4000 Europower Power Amplifier
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=248-748#Reviews
    As God is my witness, I have no need for this thing, but I was reading all night and all this power seems so cheap, I just wanted to check it out myself. Curiosity killed the cat. I want to try it driving the A7s and compare with the B&K. Also, I will rewire my car subwoofers to 8 ohm (they are dual 4ohm voice coil) and will see if it can drive two subwoofers for home theater. I will play with it for a month and will dump it here in the For Sale, hopefully for not too big of a loss :) If you are going to be interested please note, or pm me now.
    BlueFox wrote: »
