RT55i Finish Problem
I-SIG
I-SIG Posts: 2,243
edited April 2012 in Speakers
I'm putting together an office/girlfriend system. I had the chance to buy back some RT55i's from a buddy.
I'd like to figure out some way to repair the vinyl finish on the one speaker, if possible, without having a huge fuss of shipping it back to Polk or some other more expensive option.
Any ideas? The pics are below.
Thanks,
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • chumlie
    chumlie Posts: 8,658
    edited April 2012
    Just an idea. Take off the vinyl. Get some crown molding and glue it on like a picture frame.
  • Kex
    Kex Posts: 5,205
    edited April 2012
    Ah yes! The infamous heat damage! This happens when these are exposed to direct sunlight, or possibly other heat sources. It would certainly be a problem near a window in AZ or CA, as well as many other parts of the country, I suspect.
    I'm not sure what the best solution is, but maybe stripping it off completely and attempting to spray paint what I think is MDF in black? The wood trim with the grain is far more robust that the vinyl surround shown in your photos.
    Otherwise, the RT55 and RT55i are well worth saving, in my opinion: they are a great HT speaker, and very good for music as well. Excellent bass output!
    Alea jacta est!
  • Upstatemax
    Upstatemax Posts: 2,685
    edited April 2012
    Stripping and painting might be the best option. You'll want to put several coats of primer on it though.
