Tweeters not working on 7Bs
Dieselguy624
I picked up a pair of 7Bs & the tweeters don't seem to be working. These are the first Polks I've owned so I don't know much about them. Other than loose connections & such is there anything I can troubleshoot from here?
Thanks!!
Thanks!!
Post edited by Dieselguy624 on
Do they have fuses (or fuse holders) on the back by the speaker wire connections? If they do check that the fuses are good, or that the fuses are in place.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Looks like that might be the culprit, fuses are toast.
Fuses did the trick! Thanks!
