Lost stereo image
bihunter
bihunter Posts: 2
edited April 2012 in Troubleshooting
I just connected my PSW10. I used Option 2 because my receiver does not have a sub-woofer output. I checked very carefully to follow the directions, red to red, black to black. Everything sounds pretty good, but I have lost stereo. Both speakers are playing the same signal, and when I turn the Balance control from L to R and back, there is not effect.
I had normal stereo functioning right before I attached the subwoofer.
Any thoughts?
Post edited by bihunter on
    F1nut Posts: 52,146
    edited April 2012
    What is option 2?
    heiney9 Posts: 25,577
    edited April 2012
    What is option 2?
    It comes right after option 1 and precedes option 3. Everyone knows that Jesse :razz:
  • zane77
    zane77 Posts: 1,696
    edited April 2012
    I believe option 1 was was using the subwoofer output on his receiver which his receiver doesn't have.
    Two Channel
  • bihunter
    bihunter Posts: 2
    edited April 2012
    Yes, Option 1 was the subwoofer output, which I don't have. Option 2 is to take the signal off of the speaker wires. I connected the speaker wires from my amplifier to the Speaker In clips on the subwoofer, and then wired my speakers to the Speaker Out clips on the subwoofer.
    Given that the sub combines the L and R signals (below the low pass filter) loss of stereo image might be expected, but the circuitry in the subwoofer should handled that in some way. I suspect I made some kind of rooky mistake, but I can't figure out what it is. Still looking for advice or insight.
    Thanks, everyone, in advance.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited April 2012
    Hello BH,
    As a test take either the right or left channel out of the sub's circuitry and connect the positive/negative speaker in and out together. In effect removing the sub from one of the channels. See how this effects the stereo image.
    Regards, Ken
