RTi70 Tweeter Replacements
oby1
hello all,
i've researched and found some good information on replacing the tweeters in my rti70 speakers. i have found that the following tweeters will work....
SL6511
SL6506
SL6507
unfortunately these tweeters have been hard to come by. i even tried to get them new through polk with no success. i am wondering if there are any other tweeters that will fit the rti70's? i have seen many models on ebay that look very similar but none are the models listed above. i'm not worried about matching the tweeters because both have to be replaced. any help would be appreciated!!
thanks,
oby1
SL6511
SL6506
SL6507
thanks,
oby1
Post edited by oby1 on
parts express
parts express
i looked through the site but without the part numbers matching up i have no idea what to order. any particular parts on the website that i could fit into the rti70? -
Parts Express won't have a drop-in replacement. Your best bet is to buy a trashed set of speakers with the same tweeters and part them out.
finding a trash pair of speakers sounds harder than finding the tweeter. i keep looking on ebay and am finding all kinds of 65** tweeters but none of the models listed above. is there any other 65** series that will fit? i dont care if they're not the right ones i just want them to have the highs back!
