Need Help SDA 2A
westmassguy
westmassguy Posts: 6,850
edited April 2012 in Vintage Speakers
I scored a pair of SDA 2As for practically nothing. Problem #1 is they're completely disassembled. The original owner had planned to refinish the cabs, but never got around to it. So I've got several boxes of components, cabs and grills.
I've gone through all the parts, and everything is there, except the interconnect cable and the blade connectors that mount to the cabs.
Finding a two conductor panel mount connector and matching plugs/cable isn't a problem, but the schematic for the 2A posted on here is a bit confusing. The right channel is supposed to have a connector with blue and white wires, and the left channel black and white wires. These wires then connect to the spade terminals on the dimensional modules.
This is where I'm confused, between pins A & B, and which spade terminal gets which wire.
The notation on the schematic, where it says "Backwards" is even more confusing.
Any help would be appreciated.
Home Theater/2 Channel:
dhsspeakerservice.com/
Post edited by westmassguy on
