Have any of you guys heard of or seen this
gimpod
I get got an e-mail from a guy about getting a set of boards for his SDA 1C's and had the usual questions but one stuck out as I've never seen or heard of it. He say's his box's (not the speakers) has a label on them that reads as follows.
Anybody got any ideas what this means if anything.
His Serial #s are above 10700.IMPORTANT- NEW CONNECTOR
Can not be used with speaker serial number lower
Than #7500
Post edited by gimpod on
I get got an e-mail from a guy about getting a set of boards for his SDA 1C's and had the usual questions but one stuck out as I've never seen or heard of it. He say's his box's (not the speakers) has a label on them that reads as follows.IMPORTANT- NEW CONNECTOR
Than #7500
The serial number is--I'm sure--wrong for the change from blade/blade to pin/blade for the jack to connect the SDA cable. (UNLESS Polk skips serial numbers, so they aren't always consecutive. This seems the most likely)
When did Polk change the circuit boards on the SDA 1C from the 1B-style two round boards to a single rectangular board? The connectors on the rectangular board would be different from the round boards. (Why would Polk put a label on the shipping carton for this change??? Theoretically, the consumer would never be inside the cabinet to notice the difference.)
In short...I don't know, but those are the only two connector changes I'm aware of. -
Sometimes I think Polk used random serial #'s on the SDA's, you would think the right & left would be consecutive as they were sold in pairs.
Case in point in regards to the 1C's & 2B's look at your post 2B and EARLY 1C AI 1 modifications
When did Polk change the circuit boards on the SDA 1C from the 1B-style two round boards to a single rectangular board? When they ran out of the 1B cab's & boards.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Agreed. I'm sure the 1C Studio was nothing other than a way to use 1B cabinets. (black finish instead of brown woodgrain)
Well, anyway, my guess is your "mystery" connector is the SDA interconnect cable end, and it can't be used with speakers before S/N 7500 because all the ones prior to 7500--are the ones in the four serial number groups listed in my other thread that you linked to, and there's lots of skipping around and "missing" serial numbers within the 1C production. When they changed the SDA jack from the leftover blade/blade to the "correct" pin/blade, they started the serial numbers at a nice, round number (7500) and never looked back. -
Why play games like this with the serial numbers? One reason comes to mind. The competition can't look at Polk's serial numbers and determine the production quantities, unless they somehow know which serial numbers Polk didn't use.
Also volume was lower back then and almost always if you had an issue you took it back to your local dealer where you purchased it and they had the documentation for the repair. Today with internet sales, more international sales, etc as well as perhaps user fixable things like drivers, etc a formal, trackable serial number is much more important. So I could see how in the 80's and early 90's the serial number process could be a bit random and haphazard. You can bet though someone somewhere knows what they mean or used to anyway, it wasn't that random.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
H9 -
Why play games like this with the serial numbers? One reason comes to mind. The competition can't look at Polk's serial numbers and determine the production quantities, unless they somehow know which serial numbers Polk didn't use.Also volume was lower back then and almost always if you had an issue you took it back to your local dealer where you purchased it and they had the documentation for the repair. Today with internet sales, more international sales, etc as well as perhaps user fixable things like drivers, etc a formal, trackable serial number is much more important. So I could see how in the 80's and early 90's the serial number process could be a bit random and haphazard. You can bet though someone somewhere knows what they mean or used to anyway, it wasn't that random.
H9“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
The competition can't look at Polk's serial numbers and determine the production quantities, unless they somehow know which serial numbers Polk didn't use.That or the boys at Polk were partaking in a bit to much herb back in the day.________________
2 Channel-Denon AVR-4520/SDA 2.3TL's
5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
