Electronics experts: Coaxial cable question > Audio Interconnects
Turbota
I would like to make my own set of RCA audio interconnect cables. A guy on another message board made the set shown below. They really look good!
He used RG-316/U (50 ohm) Coax, however, someone else posted that RG-62/U would be a better choice. They said that the RG-62/U is a 93 ohm cable and has 1/2 the capacitance per foot of regular coax so it won't attenuate the highs as much, even on long runs.
I am confused. I saw a chart where it shows that RG-6/U is a 75 ohm Coax that is usually used in video connections (nothing mentioned about audio only).
RG-6QS is basically the same as this RG-6/U except that it is 'Quad-Shielded' and provides for better protection against radio interference and loss.
Bottom line .... There are so many different Coax cables, I don't know which one would be best for short-run 2 channel audio interconnects (patch cords).
Anybody know more about this than me?
Ron,
Ron,
2-Channel Audio
Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
Onkyo ... M-282 . ... Power Amps .(Pair)
Onkyo ... C-7030 . _.CD Player
Polk . . *. RTi A7 - ....Front Speakers
Polk . . *. RTi A3 - ....Rear Speakers
Post edited by Turbota on
BTW, the link below shown a bunch of various Coax cables and there specs as it pertains to audio use.
Problem is: I don't understand what the numbers mean.
http://elec.chandra.ac.th/tipntrick/coaxial.html#TOP
____________________________________________2-Channel Audio
Polk . . *. RTi A3 - ....Rear Speakers -
Don't sweat the "coax." Most of your high-end interconnects are solid core copper wire in any number of configurations/gauges. Why not try to build your own using braided solid core? A design similar to the Kimber PCB (an award winner) can't be that hard to copy....just a thought.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
The coax of choice for DIY interconnects is the Belden 89259 cable. Specs below:
Conductor: 22 AWG stranded bare copper
Nom. Capacitance: 17.3 PF/FT
Dual shield: 95% bare copper braid
Jacket: Black tint Teflon
Insulation: Foam FEP (Teflon)
Nom. DC Resistance: 15.0 ohm/M'
Velocity of propagation: 78.0 %
You can buy (affordably) these pre-made from www.signalcable.com (analog 2)- mention you are a club polk member for a discount.
The Analog 1 is a neat coax design also, I'm not sure what specific cable it is made with.
Cheers,
Thanks Russ, thats the cable I will use.
Now, if I can only find the Bentely Harris fiberglass cloth lined rubber sleeving, all coverd in Bentely Harris expandable sleeving that the guy used. I find other sleeving, but not the Bentely Harris. Not on Google Search either.
Ron,2-Channel Audio
Partsexpress.com has an assortment of 'techflex' sleeves, I'm not familar with the 'Bentely' name.
Cheers,
