Should I swap out my center CS245i with a CS10? Running Tsi100's
drjoeshmoe
I have two pairs of TSi100 and currently and using a CS245i as the center,
my question is, would I benefit from going to a CS10 center since it is from the same line as my bookshelfs?
Post edited by drjoeshmoe on
Most people here will tell you to timbre match your front 3, and I tend to agree. But...I was running a pair of rti4s with a cs1 (kind of the opposite scenario) for awhile back when I was just getting into this crazy hobby and it never bothered me at the time. Plus, the cs254i is a MUCH better center than the monitor or tsi counterparts. Heavier, better components, crossovers, etc. I think that you might be a little disappointed in the change in sound if you switch. If you like the sound now, I say stick with it. If you feel like there is a change in tone or timbre when voices or other sounds pan across your front stage and it bothers you, then it might be worth a shot. The best idea would be to compare in-home if possible.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
keep the CS245i, The cs1 isn't all that great anywayLiving Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
