Reversed Speaker Leads...
mikestr
mikestr Posts: 2
edited March 2012 in Troubleshooting
Hi,
I have a stereo receiver connected to PSW111 sub (speaker line level) that goes to 2 RTiA1.
I rewired them because of a new TV stand. I have accidentally reversed the the +/- speaker leads on tight channel and operated it for about 30 minutes in that situation, until I rechecked my setup.
Im concerned that I might have cause damaged to my sub, speakers or receiver???
TIA for your reply.
Post edited by mikestr on
    F1nut Posts: 52,104
    edited March 2012
    You're fine.
  • Jer.War
    Jer.War Posts: 180
    edited March 2012
    It just changes the way the speaker reacts to the incoming signal. With reverse polarity, the cones of the speakers will move inward, when they should be moving outward (with proper polarity). As F1 said you don't need to worry.
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • mikestr
    mikestr Posts: 2
    edited March 2012
    thanks for your replies F1 and Jer.War
