Results from the Impedance meter!
Mr. Sharpe
Mr. Sharpe Posts: 1,359
edited March 2012 in Speakers
So I got a nice littler Impedance meter the other day with a nice big tool bag and thought i'd have fun with it and stick to my speakers.
Results:
Cerwin Vega U-103 Hed Design - 9.2 Ohms
DIY speakers - 7.1 Ohms
and the kicker! Yamaha NS-A 635A Monitor speakers - Rated for 8 Ohms, I got 6 Ohms!
Pretty sweet little instrument. Maybe I did something on the Yamaha's but I got 6 Ohms.
A thing about my DIY's, I touched the meter to the ends of the cables going into the receiver and it read 6 Ohms. That was pretty neat finding the actual impedance of the speakers.
I've always wanted one of these meters, I had fun:)
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Post edited by Mr. Sharpe on
  • DaveHCYJ
    DaveHCYJ Posts: 89
    edited March 2012
    Its always fun playing with new tools.
    Side note: Doesn't the impedance change with the frequency on some speakers?
    F1nut Posts: 51,778
    edited March 2012
    DaveHCYJ wrote: »
    Side note: Doesn't the impedance change with the frequency on ALL speakers?
    Fixed and bingo!
  • Face
    Face Posts: 14,340
    edited March 2012
    DaveHCYJ wrote: »
    99% of speakers.
    Generally, a speaker with a DCR of 6ohms across the binding posts is an 8ohm speaker. In reality, you need a woofer tester to accurately test a speaker's impedance.
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited March 2012
    Woofer tester?
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Face
    Face Posts: 14,340
    edited March 2012
  • pyrocyborg
    pyrocyborg Posts: 524
    edited March 2012
    All speakers will dip way under their advertised impedance, expecially at lower frequencies. Take the LSi9/15 for example, they can go as low a 2 ohm, yet they are 4 ohm speakers.... but most of the time, yeah, they're over or at 4 ohm.
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
    mhardy6647 Posts: 35,029
    edited March 2012
    Fixed and bingo!
    well - in fairness... I do believe that most ribbon drivers (and perhaps some other types of planar drivers) behave as pretty much frequency-independent, purely resistive loads. Then again, a good old Quad electrostatic is pretty much a capacitor!
    BUT, as someone considerably wiser (and perhaps even more sardonic) than I once said:
    All generalizations are false, including this one
    I suspect that the impedance meter in question measures impedance at a single, fixed AC frequency? Perhaps it does a frequency sweep, and measures and displays the minimum measured impedance? I dunno - can the OP provide a name/model number?
    Here's a nice primer on impedance measurement (indeed, DIY Thiele-Small parameter measurement... even if you don't have a Woofer Tester!) and characteristics for a woofer.
    http://sound.westhost.com/tsp.htm
    This is a pretty typical frequency-dependent impedance curve for a woofer (annotated to explain various facets impacting impedance as a function of frequency) from the link above.
  • Mr. Sharpe
    edited March 2012
    Hi, yeah the meter is a G2 Phoenix Pro: DL379. Yeah I've always known there were impedance curves in all speakers, I think when it starts curving is when the frequency gets wider. Fun stuff electricity yes?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
