Problem with Output from Denon AVR 4310 & OPPO
KYFHO
KYFHO Posts: 76
edited March 2012 in Electronics
I recently purchased an OPPO BDP-95 to replace my Sony Blu-Ray due to the Sony not having 3D capability (and I wanted a nice universal player that sounded good). Since my AVR (Denon AVR 4310 CI) only has 1.3 HDMI ports, it does not support 3D.
I currently have the HDMI out on my Denon plugged into HDMI port 1 of the TV. My plan was to run the video from the OPPO directly to HDMI port 2 on my TV and run the 7.1 analog cables to the EXT in on my Denon for the sound (I specifically want this setup so I can utilize the internal DAC of the OPPO). I adjusted the settings in the OPPO to send video only through HDMI 1 and Audio via 7.1 analog to the Denon. The problem I run into, is when I play a Blu-Ray (through HDMI port 2 on TV) I only get a picture but no sound. When I switch to HDMI port 1 of the TV I get the Denon main screen with the sound from the Blu-Ray. I have messed with most settings on the Denon but for the life of me cannot get it to send sound to the speakers when my TV is using HDMI port 2. I can't find any sort of bypass or anything. Does anyone have any advice or idea of what I?m doing wrong? I have been messing with this for 4 days now and am about to swap out the 4310 with something else that is 3D capable (this would be a last resort because the Denon sounds fantastic). Thanks in advance for any advice/assistance.
Post edited by KYFHO on
  • DMara
    DMara Posts: 1,434
    edited March 2012
    Your Oppo got 2 HDMI outs; you can also plug the HDMI 2 out from your Oppo to your Denon for sound, no need for those analog cables.
    Did you assign the multichannel analog section to an output name? In your current setup, you will need to select that output name in order to get sound.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • KYFHO
    KYFHO Posts: 76
    edited March 2012
    I do not want to use the dual HDMI method as it bypasses the DAC in the OPPO. I searched all the assignment areas in my Denon and cannot find anywhere where I can specifically assign the "EXT IN" to output to a specific area.
  • mantis
    mantis Posts: 17,316
    edited March 2012
    Here's how you should have it set up.
    1) HDMI out of OPPO to TV on HDMI 2
    2) 6 CHANNEL ANALOG to DENON EXT IN
    3) HDMI out of DENON to TV HDMI 1
    4) pick an inout of the DENON
    5) Press EXT IN , forever will EXT IN will be assigned to this given input like DVD or HDCD
    HDMI from Denon has no meaning for the Oppo anymore , if you have EXT IN to an input that also USES HDMI as a video out , you will have no sound as you described.
    So go to DVD , Press on the remote EXT IN and your good. Sound and video now fixed.
    Dan
  • KYFHO
    KYFHO Posts: 76
    edited March 2012
    Thanks! I finally got it working. I cannot believe how much better this OPPO sounds compared to my old Sony. Like night and day!
