Need Help deciding!!
fonso
fonso Posts: 7
edited February 2012 in Speakers
This is my first time on the fourm. I need help decideing between a LSiC (center channel) and LSi9 (Bookshelf Speakers) or a CSi A6 (Center channel speaker) and RTi A3 (bookshelf speakers). Im looking for a clear rich and deep sound and seeing if you can help me with your opions if you know about these products personaly. I also want to know if its worth spending more for the LSiC and LSi9 rather then the CSi A6 and RTi A3. Can anyone help me please!!!!! :loneranger:
Post edited by fonso on
    F1nut Posts: 51,997
    Depends on your intended purpose and what gear you plan on using.
  • fonso
    fonso Posts: 7
    Intended use is for a home theater system. I intend to invest in some floor standing speakers and surround speakers later on. Im using them for my living room, 30x15
  • zane77
    zane77 Posts: 1,696
    I'd say for HT go with the RTi's and the CSi and add the RTi A7's or A9's in the future but that would depend on what you are going to be driving them with.
    Two Channel
  • pyrocyborg
    pyrocyborg Posts: 524
    Well... I would say LSi hand down, but I could be dead wrong because as F1 first mentioned, and zane77 after him, it depends what kind of receiver/amplifier you're using. Note that the entire LSi series impedance is 4 ohm, making them "harder" to drive, especially if you don't have an external amplifier. So, to drive them, you need a 4 ohm compatible amplifier.
    If you don't have this kind of gear, I would say get the RTi and the peace of mind. They're easier to drive and offer quite an excellent performance for HT, even if you only have a receiver.There is almost no problem using a pair of small 4 ohm bookshelf speakers like the LSi7 at low to moderate volume with a receiver... but I wouldn't even drive another speaker with the same receiver, especially the LSi.
    Also, LSi tweeters are very directional, meaning that if you always invite some people to watch movies with you, some people might not get the best experience, as only those how are in the "sweet" spot will have the best sound. However, if you're always watching it alone or with another person, there is no problem at all going the LSi route.
    Either way, I wouldn't recommend driving a pair of large towers (like the RTi10/RTiA7 or RTi12/RTiA9) with a receiver, even a high-end one. Those speakers requires tremendous amount of power (between 300w and 500w) to really sound their best... but you can power them with a separate amp when you'll get them.
    So, to sum it all:
    If you have a receiver and lower budget : RTi bookshelf
    If you have a 4 ohm capable amp: LSi
    If you want to watch movies with a lot of people : RTi
    If you want a more musical speaker : LSi
    If you don't mind having an "in your face" crystal clear type of sound : RTi
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
  • obieone
    obieone Posts: 5,077
    Welcome to the forum.
    Another vote for RTiA's. Nothing wrong with the LSi's, but if it's strictly HT, then the RTiA's will work better.
    For now I'd invest in a GOOD receiver, Pioneer Elite, Onkyo Integra, Denon 4000 series, etc. As long as it has pre-outs, you'll be good down the road.
  • packetjones
    packetjones Posts: 1,059
    I agree with everything that was said so far. As an owner now of both the A3's and the LSI9's there is a significant difference between them. The A3's are good but the 9's are great. You will need more expensive components (electronics) to power the lsi's correctly. Personally I would recommend the RTI's to start with. You will get more bang for your buck and will be able to expand the system for less. The A3's and center especially the 6 will sound amazing even powered off of a modest receiver. Add in a decent cheap sub like psw505 or many of the other internet direct subs out there and you have the foundation of a great system.
    I vote for the RTI all the way. This is coming from somone that just bought a pair of 9's this weekend.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • nhhiep
    nhhiep Posts: 877
    another +1 for Rti series if you're more into HT than music. But with proper power, the Rti12/A9 is very musical (most warm speaker of the series)
  • fonso
    fonso Posts: 7
    Thanks for the help i really appreciate it. I currently have an Onkyo ht-rc360 (was given to me) but I'm looking to upgrade. Any
    suggestions? (I'm leaning more towards the RTi series from all the good reviews) Thanks again
  • ravaneli
    ravaneli Posts: 530
    If that helps Newegg has a great sale on A1, A3 and A6 now. A6 is 276 shipped. That is a hell of a deal, just take my word for it, as I've been following the price since black friday, and u won't beat that. I got mine for 300 and I thought I had a good deal.
    Also, A9 are 539 a piece. Pretty damn good for a 100 pound speaker.
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
