crackling driver in 5r's
fro98665
Hello,
I have a set of polk 5jr's(with radiator) that I just bought for $30. One of the speakers crackles at middle volumes. It is not the tweeter since I disconnected it to make sure. I then have another driver I put it in to make sure, it crackled also.
Do I have two blown MW6502 drivers or could it be something else.
Thanks,
Fro
Thanks,
Fro
Post edited by fro98665 on
It may be a bad driver or damaged crossover component. Did you try swapping parts from the other speaker?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
