Foam Surround for Sub
fossy
fossy Posts: 1,378
edited March 2012 in Troubleshooting
I have an old Velodyne sub that needs refoaming ... is there a place that sells the kits for subs ?? Parts-express sells 12 inch woofer kits but i don't think they are for subwoofers .........??
Post edited by fossy on
  • kermit_xc
    kermit_xc Posts: 10
    edited February 2012
  • Serendipity
    Serendipity Posts: 6,975
    I would look in your local phone book for speaker repair or speaker reconing services as I have had good luck with both refoaming and reconing...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • fossy
    fossy Posts: 1,378
    thanks for the reply , & that's what I did .. took it to a repair shop ..... I was just about to buy a new sub but if I can get a little more outta the old one for a few bucks -- y not ...
  • Serendipity
    edited March 2012
    Good luck, keep us posted with how the repair went.
  • fossy
    fossy Posts: 1,378
    edited March 2012
    The repair went great ... looks like new .. Austin speaker works did a good job ... glad I didn't attempt a repair on my own $65 ... kinda pricey for a little bit of foam but after getting hooked up & plugged in the latest chickenfoot cd ....I got boosebumps ... just simple 2.1 system and sub is just to compliment the low end but the system just isn't same without it .... so it was well worth the $$$
    While I was there , they let me look at some old Macintosh speakers that had just come in .... they are gonna do a complete refurb/rebuild on them .... don't know the model but they were hugh wood cabinets ... he said they weighed in at 400 lbs apiece .... coolness
  • Serendipity
    edited March 2012
    Glad to hear you got it fixed!
