Toshiba 32" TV Screen Problem
kberg
Although VERY slight, I noticed that the lower right corner of my screen when viewing widescreen movies is a bit "warped". By this I mean that the lower right corner of the widescreen image appears to "bend up" just a bit. It is especially noticeable when there is right-to-left scrolling text when viewing CNN on full screen (the text appears to slope down a bit before becoming flat while moving across the screen). There doesn't appear to be anything I can "adjust" after I see this "curvature" problem as well when using the S&V calibration disc.
Any suggestions on what might be the problem and how to fix it, short of hiring some video technician to do it?
Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688
Sub: SVS 20-39 PC+
the tube probably has a defect in that corner, you might want to look at others and see if they have the same issueSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2
