Things that go hummmm
chargerman426
So I have a peavey irp3000 amp power my subs run off an xlr cable from my integra 9.8 pre amp. Problem is the sub is humming like crazy. I've tried to lift the ground on the amp and the pre amp... No change. If I mute the avr it stopes or if stop my DVR it shuts up. But the problem is on my other impute to so I don't think the DVR is to blam. Any ideas?
If life had more tubes it would be a lot smoother.
Post edited by chargerman426 on
disconnect your cable TV cable and see if it goes away, if so you need a ground loop isolator
http://www.ebay.com/itm/Cable-TV-Ground-Loop-Isolator-Jensen-ISO-MAX-VRD-1FF-/120416399884Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I only have direct tv and I have them running through my furman power conditioner. Should I still give it a try? Thanks for the helpIf life had more tubes it would be a lot smoother.
Have you tried running your audio from the Satbox via toslink? Power conditoners don't always break ground loops.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
+1
An optical cable provides isolation, that may work, or you can look into using a ground loop isolator but try the optical cable first. Also, make sure all devices are on the same circuit or same split-phase of your breaker panel.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
