Soundbar 4000-subwoofer not working, HELP!
rachael
Just got the Soundbar 4000 by Pol and get no sound from the woofer. It powers on but no sound. The light is slow blinking green, not a solid green. Any thoughts? Any advice would be greatly appreciated. Thank you!
Post edited by rachael on
Make sure the subwoofer is set to the same channel as the surround bar.
There is a small switch that goes from 1-4 behind both the subwoofer and surround bar. You have 4 frequencies to choose from for them to operate without interfering with other wireless objects IE wireless router, etc.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
If blinking Green it is looking for a signal, if Red it's in protect mode. Make sure you have the sub set up properly and on the same frequency, as indicated above.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
