Front ported budget bookshelf
pyrocyborg
pyrocyborg Posts: 524
edited February 2012 in Speakers
Hi!
My mother is looking for a pair of small bookshelf, front ported if possible, as they will be near a wall, wall mounted in fact. I know it's not optimal, but I guess we have no choice, as they don't want a dedicated audio room, even if they could.
I want something will as little compromises as possible in sound quality, but I know you can't have a lot of bass from this kind of bookshelf that weight less than 10 lbs.
Is it possible for under 300-400$ to have something that has a good clear sound which doesn't need to be heavy/rear ported?
Thanks!
Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
Receiver: Denon X3500H
Post edited by pyrocyborg on
  • Conradicles
    Conradicles Posts: 6,343
  • Drenis
    Drenis Posts: 2,871
    lol... I was checking out the KEF Q100's tonight which are front ported. On sale and within your budget but you don't have a Visions out your way.
    I don't really have any other suggestions.
    http://www.ebay.com/itm/PAIR-RTi4-BLACK-Bookshelf-Surround-Speaker-Polk-Audio-/360432349633?pt=Speakers_Subwoofers&hash=item53eb7131c1#ht_4418wt_1037
    Rti-4s have power ports that are less finicky about placement close to walls! Sure they weigh a tad over 10 lbs. But at this price it's a no brainer, they do most things well, and can kick a bit of bass out as well!
    I'm very happy with my Rti-4 2.1 movie/music bedroom system with a 32" flat screen and Onkyo TX-SR 604 and 100 watt 8" sub. The "value" and sound for that "value" are off the charts!
    Too big?
    cnh
  • pyrocyborg
    She already has a pair of RTi4, but they're both on the same bookshelf and really close to wall: sound is awful! lol... while it was quite right (yet bright) in my living room. But yeah, this pair will be relocated to the HT rig as it's too big for a wallmount, at least affordables ones.
    As for the in-wall, I don't know. It might work, but I know nothing about placement of this kind of speakers.
    The only problem is... if it doesn't work as espected, we end up with holes in the wall!
  • Midnite Mick
    Midnite Mick Posts: 1,591
    You might want to consider a pair of Usher s520. In your budget used and are quite a bit smaller than the Rti4 if I remember correctly. They do appreciate a little bit of power though.
    Good luck,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • pyrocyborg
    Thanks for the Usher, I might take a look as I have a dealer near! But hell, I think they weight more than 15 lbs each :(
    As for the in-wall, I've checked and it could be a great idea indeed. Too bad the LCi line sells for way too much! However, with a lifetime warranty, I guess it can't be bad?
  • ViperZ
    ViperZ Posts: 2,046
    Why not go sealed? NHT 1.3, 1.5, superone, superzero.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • D_M
    D_M Posts: 175
    A lot of people slept on the old RM series. They pop up every now and again on ebay. The RM6902s or 6901s paired with a sub will
    surprise you. They're usually listed for about $70. The VM series appear to be in the same mold as the older RMs, so I'm guessing that a pair of VM10s and the PSW111 should produce similar results. Keep checking ebay and Canuck audio mart for Vms and RMs.
  • EDUBAG
    EDUBAG Posts: 403
    audioengine p4
    www.audioengneusa.com
    front slotted, 349 bucks very nice sound.
    good luck
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • ravaneli
    ravaneli Posts: 530
    pyrocyborg wrote: »
    I am no handyman, but holes in the wall are pretty easy to undo. Especially drywall. Just buy a $5 block from home depot and cut the same piece and plug it in, with some cement. Some find sandpaper makes it so you can see with your eyes where the new piece is, but when u go over with your finger you can't detect it. Then paint.
    I had to fix several holes when I bought my place, and it was the first time i tried something like this. If I could do it, anyone can.
    after that i became very courageous about drilling holes anywhere. Keep a bottle of the same paint, then fill the holes, sand them and paint. A couple of days after the painting you can't tell where it was.
    Now i tried this with my car, and that's a whole different cup of tea. DO NOT RANDOMLY DRILL HOLES IN YOUR CAR. Those are hard to repair and match to original.
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
    EndersShadow Posts: 17,704
    Little late to the party here, but I used Infinity Primus 162's as my office fronts for a bit. They are front ported and are about the size of the Monitor 40's but a tid bit wider.
    Another suggestion would be the Primus 152's. Either would need a sub for down low.
    Also take a look at the Audioengine A2's and A5's or even their passive speakers. Same with the M-Audio 40's.
  • rooftop59
    rooftop59 Posts: 8,121
    The ENERGY RC10s are great sounding little bookies that come with a port plug. I never used them with the plug, but they are designed to be used with the plug against the wall. They smoke those rti4s in every conceivable way, and are quite small (though they do weigh about 13 each);
    http://www.vanns.com/shop/servlet/item/features/542469405/energy-rc10?v_c=netelixir&ne_ppc_id=705&ne_key_id=13275430&ne_sadid=8122906847
    Good luck!
    Game Room 5.1.4:
    Bedroom 2.1
  • Polkie2009
    Polkie2009 Posts: 3,834
    Nobody is seconding the Focal JM Labs Chorus 705v on A-gon? Front ported ,good looking speakers from a well respected company,maybe someone here who has some can add to this. I think they are 8 ohm speakers?
  • vcwatkins
    vcwatkins Posts: 1,993
    +1 on the Infinity Primus 152's. I hung a pair on a wall in our small game room at the beach and I really like them, even without a sub. Excellent value IMO if you can find on a decent bargain site.
  • malvrich
    malvrich Posts: 49
    Hey this is the Polk Forum right?
    Why not get a pair of Polk T15s at BestBuy for $100?
    If you need more of a pedigreed presentation, try Mordaunt-Short Carnival 2 for $250/pair.
  • malvrich
    malvrich Posts: 49
    BTW: the Ushers do weigh exactly 15 lb.s
    specs are as follows:
    2-way system tweeter 1" (UA025-10), mid-bass 5" (KSW2-5029B)
    Sensitivity 86 dB @ 1 watt / 1m
    Nominal impedance 8 ohms
    Frequency response (-3 dB) 52 Hz ~ 20 kHz
    Power handling 75 watts
    Crossover frequencies 2 kHz
    Weight 15 lbs
    Dimensions (w x d x h) 7.09" x 10.43" x 11.81"
    Shipping weight 32 lbs
    Shipping box (w x d x h) 17.9" x 13.0" x 15.0"
  • Tbone289
    Tbone289 Posts: 661
    If you don't mind looking for used, the Polk RT3 is front ported, and has surprising bass for its size. IMO, they sound great for music and image very well. You will not want to mount them above ear-level though, as they begin to sound "hollow" the higher they are mounted.
    RT3s can frequently be found on eBay in good shape for ~$80 per pair. They weigh closer to 12-13 lbs though...
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • pyrocyborg
    Yeah malvrich, I think it's a Polk forum! :rolleyes:
    But I tried the R/T/M series when I first bought Polk, and I really didn't like their sound... considering that for a few bucks more, I had a pair of brand new RTi4 which sounded fuller for HT. However, my mother would like a smaller speaker that offers a the kind of bass the RTi4 deliver, but with an emphasis on mid-range, instead of high-end.
    I do think the MS could offer that, but they're 4 ohm rated speakers (my mom got a Denon 500$ish receiver which can't go that low) and they're quite big, while the Carnival 1 are rear ported.
    I guess I'll take a lot at all those options that aren't deeper than 8 inches and are front ported or built to be near a wall. I do think the Audioengine P4 is a good idea. And we're looking into in-wall too, as she might get something like the Vanishing Series LS if I push it a little bit... :P I think we'll take our decision once she listen to my LSi7. If she likes it, she might be tempted to pay the extra cash for a pair of in-wall with the same kind of sound, she deserve it... ;)
  • Syndil
    Syndil Posts: 1,582
    Well, it looks like "we're" not "thinking" here guys. New Products!!
    Blackstone TL3s, light, wall-mountable, VIFA tweeter. Get a pair and a sub and you're good!
    http://www.polkaudio.com/homeaudio/blackstonetl/tl3.php
    cnh
  • Tbone289
    Tbone289 Posts: 661
    pyrocyborg wrote: »
    That description sounds like the RT3, and the more laid-back upper range is why I prefer it for music over the RTi4.
  • skrol
    skrol Posts: 3,452
    Another is the Vienna Acoustics Hayden Grands. They are front ported, very attractive and very nice sounding if you drive them properly. I have seen them go for around $400 on the used market.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • rooftop59
    I've got a pair of NHT super ones and a pair of NHT SB2s that would both work well. The SB2s are definitely superior, especially in bass. They are both sealed and therefore better for mounting. Shoot me a pm if you are interested in buying either.
    Game Room 5.1.4:
    Bedroom 2.1
