SurroundBar 360 Humming sound
AUAtty
My Surroundbar 360 has started making a high pitched humming sound when turned on. Does not matter which input I use (cable box, dvd, etc). It's so bad I can't use the system. Any suggestions on cause/solution?
Post edited by AUAtty on
Are your sources set to output PCM? You can check in the menu of your cable box/dvd/etc.
Otherwise, I would suggest contacting Polk Customer Service.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
I am having the exact same issue. Have had the unit for a little more than a year. Had it sent back two times for other issues that popped up. Contacted customer service via email this time and got no response. It is out of warranty now which is a bummer. Did you ever get this fixed? If so how?
Thanks -
I would recommend contacting Polk Audio customer service.
Give them a call, they are great!!polkaudio RT35 Bookshelves
