Another 'is the power enough' RTi7 question
ravaneli
ravaneli Posts: 530
edited January 2012 in Speakers
I saw several similar threads but still can't quite make my mind and I would appreciate some opinions here.
i wana buy this guy because it comes at 135 shipped, brand new. I already own the exact same model, and i really like the sound. This is a great deal, and all decent amps are just prohibitively expensive (afraid to buy used).
I have the manual and it mentions nothing about bridging, but can I biamp A7s somehow with it? If not, how will they run on just 80W? Ideally I would use the real channels to biamp the A7s, and the center channel for A6, and the preouts for surround, if I have surround at all (don't have to have)
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117398&cm_sp=Cat_Home_Audio-_-New-_-82-117-398
Thanks in advance!
BlueFox wrote: »
I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
But as in all things your perception is your reality.
Post edited by ravaneli on
  • ravaneli
    ravaneli Posts: 530
    edited January 2012
    I forgot to ask, if you know a good deal (even on used) on a receiver, may be 7.1, that can be bridged and have enough juice to power the two A7s pls share : )
    BlueFox wrote: »
  • flyfisher
    flyfisher Posts: 220
    edited January 2012
    Whats your budget?
    Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
    Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
  • 62caddy
    62caddy Posts: 137
    edited January 2012
    I've run my RTiA7s with a Proton D940 receiver (40 WPC; 6 dB Dynamic Headroom) with ease. Presently they are running on a 100 WPC receiver, again completely satifactorily. However much depends of your listening habits, room size etc etc.
    True biamplification would require an external crossover and modifications to the speaker built in crossover in addition to more massive amplification. In short, it's not worth it.
    Here's a good synopsis of the whole bi-amplification issue.
    http://www.audiokarma.org/forums/showthread.php?p=5344769#post5344769
    Main:
    McIntosh: MC 2155, MC 2125(x2), MR 80, C 32, MQ 101; Snell J7; Polk: RTiA7, RTiA9;
    Pioneer PL-518; A/T 440 MLa; Yamaha CD
    Vintage:
    McIntosh: MX110Z, MC 2505, MC 240, Thorens TD 145; Shure V15III; Altec 14, Boston T1000; Yamaha CDX 393 CD; Yamaha Cass
  • ravaneli
    ravaneli Posts: 530
    edited January 2012
    flyfisher wrote: »
    Whats your budget?
    To tell you the truth, I don't really have a budget. Prefer to be able to power the 2 x A7 + A6 with $300 - 400, but i prefer a good deal more than low price. For example, I could cough up 600 for an amp that is normally 1200 rather than buy one that is normally 400 for 300. Talking about new ones. Spending more than 500 on a used, often 10 yrs old amp seems crazy risky to me.
    BlueFox wrote: »
    tonyb Posts: 33,069
    edited January 2012
    That receiver has what we would say is a weak power supply. In 7 channel surround, which is what you would be using to bi-amp, I'll bet your down to around 30 watts per channel. So you'd throw 60 watts at the RTI 7's. You need a beefier receiver if bi-amping is your thing. Personally, I would look for a used receiver in the 400 buck range, a couple years old....and hook them straight up with no bi-amping. Find a receiver that has preouts too. No preouts means you can't add an amp later if you so choose to.
    tonyb Posts: 33,069
    edited January 2012
    Look at the Denon in the FM, seems like it fits the bill.
  • ravaneli
    ravaneli Posts: 530
    edited January 2012
    thanks for the help, tonyb.
    I used to measure the amps in my car with a digital multimeter. Just measure the voltage and use the formula.
    I tried this with this amp and I record no DC voltage. I checked my DMM with a few other things and it works fine. When I switch the needle to 200m in the DC voltage section, i start to read between 27 and 29, even thirty. But that's milivolts!!! How is that possible? Are my speakers even DC or AC? I get no reading under AC : (
    Sorry if these questions sound kinda dumb. I like to put popular beliefs to the test. I just can't believe that Pioneer will so grossly overstate the power of the amp from 80 to 30W. I have a pioneer amp in my trunk and that thing just HITS HARD. I have nothing but the deepest respect for my old pioneer amp. It did cost me 500 for refurbished tho, and that was 5 years ago..
    BlueFox wrote: »
  • newbeewannabee
    newbeewannabee Posts: 14
    edited January 2012
    just saw the link above...my bad
    tonyb Posts: 33,069
    edited January 2012
    ravaneli wrote: »
    An amp and a receiver are two different animals bro. Most entry to midlevel receivers drop their power the more channels you add to them. It is not a popular belief, it's fact. The stated power ratings most times is for 2 channel, not 7. There are exceptions of coarse, Like Pioneers Elite versions with the ice amps that tend to hold their power specs more faithfully in 7 channel surround and some other makers who run beefer power supplies in their receivers. Look at bench tests from Home Theater mag, or just google it, but if you look at the spec sheet on alot of receivers you'll find they state for example 100 watts at 7 channels, but put in a power supply thats 450 watts.....by my math,that doesn't add up. The entry level receivers are the worst for rated power specs, thats why having preouts to add an amp is a feature we push around here because sooner or later that upgrade bug hits and those big speaker you were drooling over suddenly are within your reach.....but your avr won't be up to snuff to power them. It's more so an ounce of prevention is worth a pound of cure type of thing.
  • larry777
    larry777 Posts: 480
    edited January 2012
    Yes,that Denon AVR 3808 in the F/S section would run those RTiA7's nicely. The Denon offers a lot for the money, including Power.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • ravaneli
    ravaneli Posts: 530
    edited January 2012
    my amp has preouts for front height or rear surround. Is that what I need to hook up an amp?
    Sorry for stupid question, don't know if you need separate preout for every channel..
    BlueFox wrote: »
    tonyb Posts: 33,069
    edited January 2012
    ravaneli wrote: »
    Nope, you need 5.1 preouts or 7.1 Front left and right, center, back left and right....to be more exact. Don't know of any receiver that has preouts for surrounds and not the front though. What receiver are you using ?
  • ravaneli
    ravaneli Posts: 530
    edited January 2012
    tonyb wrote: »
    It has only one set of pre outs, and they can be rear surround OR FRONT HEIGHT. I don't even know what front height is. When u use them u have to make a selection in the menu to say how u use them.
    Can I use those front heights to hook an amp for the RTIs?
    BlueFox wrote: »
    tonyb Posts: 33,069
    edited January 2012
    Nope, not what you need bro.
  • ravaneli
    ravaneli Posts: 530
    edited January 2012
    I just can't cough up that much money for an old denon AVR.
    My A7 already arrived (gota go pick them up tonite)
    Will hook them in 2.0 stereo mode tonite to see if my pioneer can drive them at all. It's power supply says 435W. At 80% efficiency that should be 350, so like 70W per channel. Of course not considering where distortion comes alive. But the front two are quite possible to be true to its rating of 80W imo (20-20k hrtz 80W, 1khz 110W)
    BlueFox wrote: »
    tonyb Posts: 33,069
    edited January 2012
    ravaneli wrote: »
    Old ?? That receiver has everything a modern one does, HDMI, DTS HD master audio, etc. 400 bucks is a good price and believe me, I have no interest in the sale at all. But, if ya don't have the coin, ya don't have the coin. The receiver you have will do ok in 2 channel mode, just in 5 channel or 7, keep the volume under control dude.
  • ravaneli
    ravaneli Posts: 530
    edited January 2012
    acually i didn't mean to say old. I checked it out and it's a gorgeous receiver. I meant 'used'. If I overload it accidentally with the A7s and it blows, i have no warranty or anything.. I guess it's a subjective matter of risk tolerance..
    Will report on my pioneer driving those two tonight.
    The thing is, I am looking for a good deal on a A6 as well, but I am getting an A6 for sure. So the Pio will be quite loaded .. But that's just a test. I will have to get something with more juice for the front 3..
    BlueFox wrote: »
    tonyb Posts: 33,069
    edited January 2012
    ravaneli wrote: »
    It's impossible to blow that receiver with those speakers. Maybe you don't understand how this all works, and I'm just trying to save you some headaches down the road. The first thing that will blow...will be your brand spankin' new speakers, likely the tweeters. You can use that Pioneer, but if you start blasting away on the volume dial in 7 channel surround, your going to be in dangerous territory. Incidently, I don't think even new receivers are covered when driven into clipping. It's only natural to turn up the volume when you get new speakers, I understand that, just be carefull is all I'm saying. Rock on.
