Use Proceed Amp 2 with SDA 2B
huy
Hi Polkaudio members,
I am using SDA 2b with old Pioneer receiver. Just have an used Proceed Amp 2 from friend. I want to hook SDA 2b to this amp but I don't know Proceed Amp 2 is common ground or not. I tried to use VOM to check continuity between 2 neg black speaker binding post, i am getting ~ 0 ohms.
Anybody can help me to check the Proceed Amp 2 common ground or not?
Thank you
Thank you
Post edited by huy on
as long as you are getting 0 ohm you're fine as long as there is it is 0 and not showing nothing that is. What are you using for a preamp? or does that pio have preouts on it? You can not run the amp off of the speakers outputs you will fry it. Welcome to club polk.
Dudeinaroom,
Thank you for your prompt reply. I am going to use nuforce HDP with this power amp (nuforce HDP incorprates DAC, headphone amp and preampt output).
