Speaker Recommedations
nikolas812
nikolas812 Posts: 2,915
edited January 2012 in Speakers
I was hoping you all could give some recommendations on speaker choices.
I just need something to listen to. I've been with out tunes for close to a year now.
Associated gear.
Jolida 1501BRC Integrated
Jolida JD100 CDP
All Signal Cables.
Price willing to spend. $300-$500
Canidates so far.
LSi7's and sub of some sort?
SDA 1c's
SDA 2b's
Any other recommendations will be appriciated.
Nik
Post edited by nikolas812 on
    heiney9 Posts: 25,217
    edited January 2012
    Room size?
    I vote for the SDA's and then add RD0's and a x-over refresh.
    Btw, I still have and use the HCT hybrid tube amp you sold me.
  • nikolas812
    edited January 2012
    That HCT is a fun little amp. Glad to hear you've still got it.
    As far as room size. I'm not sure exactly. I'll measure when I get home. But its prolly around 12x14 give or take. Not very big. Living room. Couch, love seat, coffee table and tv...
    I'm leaning towards SDA's also. I can take the money I would need for a sub with the LSi's and put towards Tweeters and crossover mods...
    i'm also not opposed to any non polk speakers either... Just looking for bang for buck and something thats going to marry well with the related gear..
    Nik
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2012
    Nice lsi7 with the tubes, I did get to hear some zu towers last month and they were nice. There has been a buzz as of late about KEF's new bookshelfs so you may wana check into that
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2012
    nikolas812 wrote: »
    Canidates so far.
    SDA 1c's
    SDA 2b's
    Heard all three. Still own all three. The LSi's are very nice, especially if you have a space constraint, but there's nothing like SDA's if you've got the room. I vote SDA's.:wink:
    Also, consider the Magnepan MMG's (or possibly even MG-12's, depending on the deal), if you're into that type thing.:biggrin:
    edited January 2012
    Not sure the Jolida would power the Maggies properly, but a good suggestion too.
  • falconcry72
    edited January 2012
    heiney9 wrote: »
    The wattage is good, as long as it does well with a 4ohm load.
    edited January 2012
    Doh, I forgot that's a hybrid, with tubes at the input but solid state at the output. Should work with Maggies.
  • nikolas812
    edited January 2012
    The MMG's were actually at the top of the list at one point. But after some research found that they can be a little anal as far as postioning and the sweet spot is very small. Im wanting something with a little easier placement and more forgiving as far as power is concerned. Plus. Thats another speaker that would need a sub... I'll hear them someday. There just not the NEXT speaker for me.
    Nik
    edited January 2012
    nikolas812 wrote: »
    Nik
    Yes, and Yes
  • falconcry72
    edited January 2012
    nikolas812 wrote: »
    ...Im wanting something with a little easier placement and more forgiving as far as power is concerned. Plus. Thats another speaker that would need a sub...
    SDA's it is, then!:biggrin:
  • marvda1
    marvda1 Posts: 4,904
    edited January 2012
    try the old onix reference one at about $400 or one of the new line onix speakers on clearance.
    Puritan PSM156
