DVD-A burning software
cwsmith68
cwsmith68 Posts: 434
edited January 2012 in Troubleshooting
Can anyone in here suggest some DVD-A burning software for me to try?
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
  • CoolJazz
    CoolJazz Posts: 570
    edited January 2012
    I've had good luck with the Cirlinca software. You can download and do a few burns for free, so it is a try it first situation. Then if you decide to buy, you just get a code by email to plug in and authorize it.
    http://www.cirlinca.com/
    It has been pretty easy to use. I went with the Ultra version and have played with upsampling a couple of times redbook material just for fun. Otherwise the Standard is probably just as good.
    I've burned all my high-rez downloads with Cirlinca and have had no problems. They even happened to upgrade versions and as per the one year upgrade policy, got the new version free.
    The trial does say something like 5 burns over 5 days, but I must have misread it and couldn't get the trial to work after a couple days and only a couple burns. No big deal though as I was able to uninstall and wipeout everything and redownloaded and did another burn before I went ahead and bought it.
    Recommended!
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • cwsmith68
    edited January 2012
    Thanks! I'll give it a try!
    Main system:
    gudnoyez Posts: 8,132
    edited January 2012
    Have you tried any Nero products? I have an extra copy of Nero 8 that you could have.
  • thsmith
    thsmith Posts: 6,082
    edited January 2012
    I ripped queen NATO using dvdshrink and used Nero to burn.
  • cwsmith68
    edited January 2012
    Will Nero bur audio to dvd? I have NERO 10
    Main system:
  • cwsmith68
    edited January 2012
    i HAVE A FEW RIPPED sacd'S THAT i WAS WANTING TO BURN ONTO DVD-A. iS THAT POSSIBLE?
    Main system:
  • thsmith
    edited January 2012
    cwsmith68 wrote: »
    Not that know of.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2012
    If you have ripped tracks of an sacd you can burn them to a dvda as long as they are in the proper format. If you have them in a dsd format they are more than likely not from an sacd and someone is just trying to make them elves look cool. As far as I have seen the only way to copy SACD is using an un-updated !st gen PS3, but I want to say it converts the signal to a PCM bitstream. Either way it should still sound decent.
    There is also DVDA Author, it's a free program. Have not used it yet, and I do not know what input formats it accepts.
  • cwsmith68
    edited January 2012
    Thanks guys for all of your thoughts and suggestions!
    Main system:
