Onkyo 709/809 or Pioneer CS-55??
gtaudio
gtaudio Posts: 29
edited January 2012 in Electronics
I have the opportunity to get an amazing deal through a local dealer on a Pioneer sc-55. I am struggling because I also think an Onkyo 709 or 809 would be nice too. If I get the sc-55 I probably wouldn't need to do a separate amp.
As a reminder I have all an all Rti setup with A7s and A6 center on the front stage.
I have had three Onkyo's but none with pre outs or I wouldn't be looking.
I don't need AirPlay as I have two airport expresses and an apple tv but it could be nice if integrated well.
The main reason for looking at the Pioneer is the class d amp and 720 watts driving all channels will be nice.
Post edited by gtaudio on
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2012
    I would go with the Onkyo 809 and an amp.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • chumlie
    chumlie Posts: 8,658
    edited January 2012
    I would go with the cs-55. You can always amp it later if you feel the need. Doubt you ever will though.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited January 2012
    What?! Sc55 all day long for the better amp section!
    Plus onkyo can't handle 4ohm loads, in case you get some 4 ohm speakers later.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • Glowrdr
    Glowrdr Posts: 1,103
    edited January 2012
    I'll second the SC. I kind of had the same thought process a while ago. My decision was to go with something that I can make do for quite a while, and get all the bells and whistles, as well as the most current formats. Why buy a receiver if you know you'll need an amp?
    Guess it all depends on your setup. If you know for sure that you will be needing an amp in the near future (planning on any large speaker purchases?) then save your money and get the Onk. Otherwise if you're on the fence and just looking for a quality peice of equipment, I'd go with the Pio.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • gtaudio
    gtaudio Posts: 29
    edited January 2012
    Thanks guys obviously I got the SC backwards, I am a little worried the Pioneer might be too tall for my current rack, which I like a lot.
    Does the Pioneer run hot?
  • domflane
    domflane Posts: 653
    edited January 2012
    It's class D gtaudio, runs cool as ICE. Mine drives my RTiA home theater to some high volumes without breaking a sweat. Hate to say it, but it easily bests my HK AVR354/Carver AV-505 combo I had before. The Onks are good receivers, but the Elite SC's are amazing receivers. Be prepared to be really confused with the operation of it if you buy it though, its a pretty complicated machine, lol.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • blueboxer
    blueboxer Posts: 621
    edited January 2012
    I love my SC-35, and I hear the 55 is even better with a better overall sound and musicality with the new digital amps. Mine runs inside a BDI vented cabinet and it never gets more than lukewarm. If you don't mind PM me the deal on the SC-55, been looking to pick one up.
  • jbooker82
    jbooker82 Posts: 1,627
    edited January 2012
    I have been told thePioneer has one blanket XO setting for all channels. The onkyo you can set the towers to 40hz, center to 60, and surrounds to 80.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Drenis
    Drenis Posts: 2,871
    edited January 2012
    jbooker82 wrote: »
    This is true for the Pio.
  • Glowrdr
    edited January 2012
    Jut thinking out loud, but for a seamless transition, logically I wouldn't think bad of having all channels crossed at the same frequency. I understand each speaker (model) performs at it's own peaks, but from a sound perspective I'd think it wouldn't matter? Kind of like the same way you want the same line of speakers.
    Again, I can see both sides of the fence - just thinking out loud to get other opinions or a good debate at least.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • gtaudio
    gtaudio Posts: 29
    edited January 2012
    I don't know that it's a deal killer but I do like independently setting the speaker crossovers on my Onkyo.
  • Lietuvis91
    edited January 2012
    I use to think the ability to set different crossover points was a good thing, but after trying out different speakers and different settings I realized a few things. The reason you try to buy speakers from the same series for a matching 5 channel system is so that everything sounds uniform. If you set different crossover points for different channels... things no longer sound uniform. I have experienced this with my monitors and lsis. So really, the only reason to set different channels with different crossovers is if you are trying to blend something in that isn't designed to blend in from the get go, like speakers from different manufacturers or different series. My point is, if you are starting from scratch, you are going to buy matching speakers all around, making different crossovers unnecessary.
  • jbooker82
    edited January 2012
    Then your limited by by the smallest speaker in your system. So if you have book shelf rears then you might as well have a 5 channel book shelf system.
    Pioneer's biggest selling point is the ICE amp. So take in consideration weather or not you actually plan on using it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • gtaudio
    gtaudio Posts: 29
    edited January 2012
    I do plan on using the amp, although its the d3 amp this year they dropped the ICE amps. Still a d class amp with lots of power driving all channels.
    I agree that you are limited by the smallest speaker I have A7s in front and four A1s as surround.
    The main point of the receiver is the amp and not needing an external amp, keeps things clean in front. Also the apple integration is nice.
  • B Run
    B Run Posts: 1,888
    edited January 2012
    My Pioneer SC-35 sounds better than my Onkyo 3008 did hands down.
  • mantis
    mantis Posts: 17,561
    edited January 2012
    jbooker82 wrote: »
    This is not even a problem in any way shape or form. There is absolutely no need to set the crossovers all all different points for ones speaker package. IF you buy all your speakers from the same series , they all work together. Crossover ALL channels at 80hz and your done. Let MCACC make these decisions for you and your worries are gone. Forget all that crap.
    You subwoofer should be of highest quality for your speaker package and do all the heavy lifting , this makes for the best sounding most dynamic theater system possible with your given speaker package.
    The SC Elite receiver are superior to most receivers sold and the best in all their price classes. The Onkyo / Integra models are fantastic in many ways but don't sound no where near as good as the Elites do.
    Dan
  • Lietuvis91
    edited January 2012
    I think Mantis is dead on the money. Well said sir.
    In my particular case 120hz accross the board sounds the best for HT. This brings out unbelieveable clarity and detail and the 12in sub does a great job handling the rest. For music I switch to stereo mode, turn off the sub, and set the lsi9s to full range. Settings for HT vs music will differ, just the nature of the beast.
