PSW110 - No Auto Start
thesebastian
thesebastian Posts: 4
edited January 2012 in Troubleshooting
Hi, I'm having a problem with my PSW110 Subwoofer. There is no auto-start (Orange light not changing to green).
The only way to turn it ON, is "re-connecting" the RCA cable when my receiver.
After i reconnect my RCA plug the light turns green.
I'm using a Denon AVR-1712 Amplifier and the subwoofer pre-out mono output..
This problem could be an RCA cable problem?
Post edited by thesebastian on
  • thesebastian
    edited January 2012
    I'll try with a new RCA cable because the one i have, maybe is not working well..
    I need a 3 meters cable (10 Feets).
    What's better for this?
    >> A "very low cost and regular" RCA cable? (One of the regular white/yellow/red cable)
    >> A good S/PDIF 75Ohm coaxial cable with RCA terminal?
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited January 2012
    Hello,
    Keep in mind that is a three position switch and you want the middle position for "auto". It can be a little tricky the switch doesn't have a very long "throw" and it's easy to miss the center position.
    Regards, Ken
  • thesebastian
    edited January 2012
    Yes, i'm using the middle position (AUTO).
    I just bought a 3 meters cable RCA to RCA Puresonic brand. I'm going to try it later and give a more feedback this week.
  • Glowrdr
    Glowrdr Posts: 1,103
    edited January 2012
    I ran into the same issue with a DSW660wi that I picked up a few months back. What I ended up having to do was turn the level way up on the sub (from the reciever side). I think my receiver calibrated it for something like -8. I had to put it at +5 and just lower the volume itself on the sub. I think they could have made these a little more sensative to the incomping line levels, because it appears they need a pretty strong signal to auto on.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • thesebastian
    edited January 2012
    I think the problem is now fixed (at least for now...), with this new RCA cable!
    So the problem was that old RCA cable broken or something...
    Thanks to everyone for the help and for sharing your experiences about this.
    Regards,
    Sebastian.
