For those of you who ordered Gaskets from Mike (brgman)
audiocr381ve
audiocr381ve Posts: 2,588
edited January 2012 in Vintage Speakers
Did you glue the gaskets to the driver? If so, what adhesive did you use?
Post edited by audiocr381ve on
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    No. Don't glue them. The screw pressure will seat them.
    Too much **** to list....
  • audiocr381ve
    edited January 2012
    SDA1C wrote: »
    Ahh, cool. Thanks, you're on a roll lately. You're officially on my "good guy" list :P
    F1nut Posts: 52,000
    edited January 2012
    The originals were glued for reason. Any white glue should do the trick. Alrene's Tacky Glue works great.
  • audiocr381ve
    edited January 2012
    Gotcha! Thanks dude
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    Why is that? Seems a bit redundant to glue them. Other than from a manufacturing standpoint and ease of assembly.
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2012
    Gluing them will keep them in place. Like F1 said elmers glue or equivalent should work.
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    Joe08867 wrote: »
    That's sort of what I thought. So will laying the speaker on its back to install them and letting the pressure stick them to the driver. They wont stick to the wood on the cabinet so... I don't glue mine. I don't like extra adhesives. Either way I'm sure it work fine,.
  • brgman
    brgman Posts: 2,859
    edited January 2012
    I just sniff the glue then install the gaskets.Works fine.I think.:eek:
    I’M OFFENDED!!!!
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    Gotta be that rubber glue or it ain't worth sniffin'. LOL.
    I was building the woodwork and AV installation for a Prevost Coach some years back and had to apply a large area of contact cement. I was young and thought "Hell , I'm gonna spray this from a paint gun"
    I promptly learned it wouldn't spray so I thinned it with lacquer thinner then spent about an hour in the back of a bus with this mix and no respirator.
    That might explain a lot .lol
  • gimpod
    gimpod Posts: 1,793
    edited January 2012
    I just use a glue stick, it doesn't dry hard and is fairly easy to get off if needed.
    SDA1C wrote: »
    Now I understand what's wrong with you!
    Sorry man but you did leave the door wide open on that one. :cheesygrin:
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    You use that just to hold it in place long enough to put the screws in or is there any other reason glue would be necessary?
    They don't have names for all of my issues lol!
  • falconcry72
    falconcry72 Posts: 3,580
    edited January 2012
    I would think that the glue would be less necessary if you've got a nicely torqued set of Larry's rings in there.
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    +1^^
  • gimpod
    gimpod Posts: 1,793
    edited January 2012
    SDA1C wrote: »
    Correct, I even use it to hold down my mouse pad.
    They don't have names for all of my issues lol![/QUOTE]
    I hear ya there, There's crap wrong with me that they don't even know where to begin. :eek:
  • SDA1C
    SDA1C Posts: 2,072
    edited January 2012
    i saw this link once and from then on I am terrified of all things gooey near my speakers. I believe it was non-Newtonian fluid. Really freaky lol.
    Nope ...no liquids for me of any kind near my SDA.
  • brgman
    brgman Posts: 2,859
    edited January 2012
    gimpod wrote: »
    I hear ya there, There's crap wrong with me that they don't even know where to begin. :eek:[/QUOTE]
    But we love ya just the same gimpod!:cheesygrin::cheesygrin::cheesygrin::cheesygrin:
    I’M OFFENDED!!!!
