Opinions on Polk SDA SRS 2.3 Speakers
I am new here and am trying to learn. Does anyone have experience with the SDA SRS 2.3 speakers? They look impressive, how much power do I need to drive them?
Post edited by MarkSLR on
I don't know about the SRS 2.3, but I have the 2.3 TL (later version of the same speaker), and drive it with 45 watt tube amps to excellent results. I'm extremely pleased with mine after a crossover upgrade, though I also quite liked them before I did the upgrade.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Quad have you ever measured the spl output you get with that tube amp?
always wondered how much oomf i would get through mine with tubes
and OP the 2.3tl's are quite nice with mods especiallyMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I drive my modded 2.3TL's quite nicely with ~150 wpc of solid state, high current power. I would advise getting quality amplification. You can do well used if new is too rich for your budget.
Do a search here for some brands that folks like. My power amp is an Odyssey Stratos Stereo Plus.
BTW welcome to CP!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
You need to be sure that whichever amp you use has a common ground on the speaker outputs or bad things can happen when the interconnecting cable is used. Do you have the IC cable ? Welcome to the fray !
I've always wanted a set of sdas and I see a nice set of srs compacts for sale. Will this sound as well as my 10Bs only with the SDA imaging?
Middle Age wrote: »I've always wanted a set of sdas and I see a nice set of srs compacts for sale. Will this sound as well as my 10Bs only with the SDA imaging?
IMO better, but the 10B's are one of my favorite vintage Polk speakers..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Ty for response. I'm going to take a litle guilty pleasure and buy them. I hope they give me some of the thrill of the first set of sda 1s I heard back in the early 80's.
Middle Age wrote: »I've always wanted a set of sdas and I see a nice set of srs compacts for sale. Will this sound as well as my 10Bs only with the SDA imaging?“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
You are correct. I should have said sda compacts. I hope toolfan understood which ones I meant.
The entire SDS SRS 2 line is my personal favorite form factor. Many consider the SDA SRS 2.3 TL as best of breed, even over the big boys.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
