SDA 2 drivers
cwsmith68
I picked up a set of 4 drivers for spares or whatever. All 4 are stamped SDA-2.
2 of them are mw 6511's and 2 are mw 6503's. Is that right? 2 different models for the same speaker? All are also stamped September 1987
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
Is that right?
Yes.Political Correctness'.........defined
President of Club Polk -
Yep that is correct!!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Yes there out of a set of SDA 2B's.
The MW-6511's are the Dimensional drivers.
The MW-6503's are the Stereo drivers.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Great. ThanksMain system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's -
Do you have a set of SDA'sPolk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Put some JB Weld on them Beeyotches quick ! (to prevent shifted magnet-paperweight syndrome) A long history of defective glue jobs plagues these drivers and renders them useless........ with great regularity!:eek:
Are the MW-6510's also plagued with this problem? -
All of them, AFAIK.
Yes!! I have handled over 100 MW's and have only lost 2 of them but I do agree about JB Welding them, I do it on all upgrades.Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Put some JB Weld on them Beeyotches quick ! (to prevent shifted magnet-paperweight syndrome) A long history of defective glue jobs plagues these drivers and renders them useless........ with great regularity!:eek:“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
By all means JB Weld them
Dumb question time. This is the first time I have heard of this. Does the glue go around the outside (back) plate where it meets the magnet? -
After examining countless frozen 6.5" Polk MW drivers I'm gonna' hafta' stick with defective as my descriptor for the glue jobs. In some cases, as little as one quarter of the available gluing surfaces were coated with glue/adhesive/epoxy or whatever that lame stuff is. Bad choice of material coupled with shoddy QC and oversight, equals....... paperweights.
No. Toolfan66. I don't own any SDA'S. Just thought I would grab these for any future projects of mine or to help out anyone that may be in need of these. I have an RTA 12B project that I will be taking on as soon as the shipper settles on the damage claim.Main system:
