Studio Black SDA
SDA1C
SDA1C Posts: 2,072
edited July 2012 in Vintage Speakers
Just wondering but what is the largest, most power handling SDA in studio black? I like the piano top but not nearly as much as the Black vinyl. I thought I saw a 2.3 in the studio vinyl but not totally sure as the pics weren't great.
Thanks, 1C
Too much **** to list....
Post edited by SDA1C on
    Toolfan66 Posts: 17,434
    edited December 2011
    No such thing as a 2.3 studio, you own the largest studio version.
    VR3 Posts: 28,911
    Someone likes black vinyl??? Hmmmmmmmmmm
  • SDA1C
    SDA1C Posts: 2,072
    Toolfan66 wrote: »
    I was afraid you say that. If I could find the original cabinet plans I would seriously consider speaking to my buddy with the cnc router. It'll buzz a 3/4 sheet of mdf in about 45 seconds.
    If only I could clad them in black latex:twisted:...'nother thread...or maybe forum on that one though.
  • audio_alan
    audio_alan Posts: 770
    Why not try your hand at making some "Piano Black" tops? Paint, sand, paint, sand, paint, sand, paint, sand, paint.... It's time consuming, but it should look better than black vinyl/latex. It would also blend in well with other black speakers...
    Just a thought.
    EndersShadow Posts: 17,598
    Or just take the caps off and have them sprayed piano black at a local body shop? Wouldnt think it would cost too much. I believe someone here did that to theirs.
    heiney9 Posts: 25,236
    SDA1C wrote: »
    You could have used the cabinets you gave away when you parted out the 1C's. Those were the standard issue cabinets. You could have refinished those in black w/piano finish end caps much easier than converting a pair of "studio version" cabs.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | BlueSound Node3 - Tubes add soul!
    Studio version cabs, don't have end caps.
    The studio version of the 1C was made to be a little cheaper than the standard cabinets. They were $200 less a pair for the cheaper cabinet style (studio). It doesn't have the bracing nor the real wood end caps of early regular cabinet 1C's. Later regular cabinet 1C's had real wood laminate, IIRC.
    IMO, always go for the regular cabinet vs. the studio cabinet, they are built a little better with better damping and vibration control and are hands down aesthetically better looking.
  • SDA1C
    SDA1C Posts: 2,072
    heiney9 wrote: »
    IMO, always go for the regular cabinet vs. the studio cabinet, they are built a little better with better damping and vibration control and are hands down aesthetically LOOK LIKE **** in a blackened room.
    Fixed it for ya!
    seriously...
    I don't want to change my beautiful studios. If I liked the wood better I would have kept the others instead. I do not like wood nor shiney black.
    To the point of internal bracing... I happen to have a chance cube here lol... JK. I do however have a set of studios that I know like the back of my hand and right next to them I have a set of EMPTY standard version and the bracing is exactly the same.
    When did they change the bracing?
  • SDA1C
    SDA1C Posts: 2,072
    heiney9 wrote: »
    ohhh I get it...you weren't paying attention, again. I am considering building a set of 2.3 studios (3/4 medite clad in black vinyl).. If I had the original routing plans I could have a buddy zip out the front panels.
  • SDA1C
    SDA1C Posts: 2,072
    I considered this while I was a midst. I did notice it would be quite easy to do that. In fact the sides and top already covered in black vinyl so it would be no more than popping off the tops. However, the pr is in a lower spot in relation to the floor. One thing I did notice was a (don't want to say muddy) more spread out less focal bass response. It seemed to bounce off the floor instead of your chest. I rather prefer the studio in all aspects. Definitely a great suggestion I just chose to go a different direction.
  • SDA1C
    SDA1C Posts: 2,072
    audio_alan wrote: »
    Just a thought.
    I considered this for a brief moment but it doesn't really suit my style. I don't care for shiny tops and the extra work just wouldnt justify the reward (there is no reward to me in shiny top lol)
    I have considered the rta 15 that has the piano black top. In that event I would put some glass ontop of the studios and it would mimic the piano black with out the work.
    SDA1C wrote: »
    What tops? Studio versions don't have end caps (that's what I assume all are talking about when they say remove the tops) SDA's with end caps can have the end cap (top) removed. Studio cab's don't have a "top" that can be removed. I have seen a standard cabinet in black, not sure if it was factory issue however.
    Also in relation to the studio vs the standard that is my opinion that they are more pleasing to eye, so try not to take things so personally. If you love your black studio's then I'm happy for you.
  • SDA1C
    SDA1C Posts: 2,072
    I didnt see the IMO, sorry bout that.
    If you look closely at the standards I have they are in essence a studio version with caps and sides glued to it.
    Let me snap some pics real quick.
  • Conradicles
    Conradicles Posts: 6,169
    These looked preety sweet...A guy on the forum painted the end caps.
    Pics are fine but I'm fully aware of the Studio and Standard cabinets. The PR is in a different position look at the spacing between the bottom MW drivers and the PR's. The PR sits lower in the Std cabinet and it's not because the cab is shorter, it physically sits lower.
  • SDA1C
    SDA1C Posts: 2,072
    Note the difference in distance to the driver arrays between the standard and the studio. I don't think is correct. I think I might have a set of sda1c studios and sda1 studios modified to look like standards.
    I might have just run into something interesting. These might be 1's not 1c's...
    anyway heres the pics of interesting differences, and similarities
    There were some variations when they changed to a new generation. You could also have 1B's.
  • SDA1C
    SDA1C Posts: 2,072
    Those do look sharp Conradicals. I wonder when and what models the 1c had the longer spacing between the PR and the array.
  • SDA1C
    SDA1C Posts: 2,072
    heiney9 wrote: »
    Why clad in vinyl just to clad in wood? I also have staples that were pushed back up into the cabs of the standards. It looks to me like these were seriously modified to mimic the standard version.
    SDA1C wrote: »
    1C standard cabinet
  • tommyt21
    tommyt21 Posts: 685
    New "younger guy" here what model speaker is that it's gorgeous!
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
    nooshinjohn Posts: 25,534
    When I owned these speakers, they hade side panels on them covered in grill cloth. the vinyl underneath was the way they came from the factory. They were NOT studios.The only mod I made was to alter the side panels so that they looked more like the 3.1TL's and the SRS.
  • SDA1C
    SDA1C Posts: 2,072
    Thanks for the clary John. Did you ever take off the bottom caps?
    I completely tore down my 1C's picked up some solid oak wood and made new end caps, made new side panels as well. They look fantastic with the darker wood as I am not fond of the blond wood caps that came with them. They can be a pain to get the old ones off from the glue and staples to hold them in place.
  • SDA1C
    SDA1C Posts: 2,072
    I am leaning towards a set of 2.3 in the black vinyl...however, I am also putting some serious thought in doing some fun stuff with this set of cabs I can't seem to get rid of. Those piano blackies look bitchin! lol. The thought of black walnut has crossed my mind as well. The whole "solid wood" would certainly be the only way to go. particle board is kind of cheesy for a total rebuild material.
    tommyt21 wrote: »
    They are SDA 1C's
  • WilliamM2
    WilliamM2 Posts: 4,786
    If you want black 2.3's, why not stain the real wood veneer black? Vinyl looks cheap, and is much less durable. I was more than happy to pay an extra $200 for real wood and cloth sides when I got my 1C's back in '89.
    WilliamM2 wrote: »
    If you want black, why not stain the real wood veneer black? Vinyl looks cheap, and is much less durable. I was more than happy to pay an extra $200 for real wood and cloth sides when I got my 1C's back in '89.
    I did that with a set of 2B's and they looked ok but I was not wowed by it then when I took on the 1C's project I did the same thing and that's when I was like f#*k this I need to get some real wood and just do it right. I made the right choice they look great and it pushed me to do my 1.2tl's..
  • SDA1C
    SDA1C Posts: 2,072
    I prefer the look of the full face grill. The wood or top hanging over the tip of the grill just looks stupid to me. The vinyl being less durable is subjective I'd say. Mine are near mint and have the vinyl. I see the set next to me that had a veneer redo and they are still less on the condition scale than my studios. I have some light fading in my grills (very slight) and a nick in the lower left side where the vacuum scraped by (God bless her! lol). Other than that they are show room. I think durability is more of a how they are treated when you are talking finishes or coatings.
