connecting a jantzen capacitor to speaker terminal on my lsi15's
deseroner
deseroner Posts: 155
edited December 2011 in Troubleshooting
i was wondering wondering what would happen if i connect my jantzen z-silver 800v capacitors to my lsi15 speaker terminals not the crossover board, i already did the mods to my lsi15's on the crossover board , i was just curious what would happen . by connecting + to + and - to -.I want to try these capacitors out without removing my other capacitors, these look like a 100uf,they look like baby grenades ,they are only 12 uf and 22uf.
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    You would end up filtering out the highs.
  • Face
    Face Posts: 14,340
    Sounds like a bad idea..
    Sure about that? ;)
  • deseroner
    i want to try it ,but iam scared iam going to f it up. i just might do it on the crossover . lazy.
  • Face
    Face Posts: 14,340
    Lazy and incorrect.
  • dudeinaroom
    Face wrote: »
    Sure about that? ;)
    nope;)
  • FTGV
    FTGV Posts: 3,650
    deseroner wrote: »
    i was wondering what would happen if i connect my jantzen z-silver 800v capacitors to my lsi15 speaker terminals not the crossover board...i was just curious what would happen . by connecting + to + and - to -....
    My guess is your Pio AVR would protest vememently seeing a capacitive load as such.
    Toolfan66 Posts: 18,224
  • deseroner
    alright just got done installing on crossover , custom fit, i removed my sonicaps . sound so far with the silver-z is clear and crisp ,loving it .
