Which resistor?
Phasewolf
Phasewolf Posts: 514
edited December 2011 in Vintage Speakers
I am getting ready to rebuild my xovers and was looking at both Mills wire wound and Mundorf MOX Resistors. I know a lot of people like the mills has anyone used the Mundorf and if so did you like them or should I go with the Mills that most seem too use?
The Mundorf is a metal oxide film resistor is there any down side too that?
Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1
Post edited by Phasewolf on
  • newbie308
    newbie308 Posts: 800
    I have no experience with the Mundorf resistors, but typicaly metal oxide film resistors are not rated for many watts. I have used many Vishay metal film resistors in the preamp section of a Fisher 600, and in a Dynaco preamp, but they were all 1/2 watt or less. The results were fantastic (like someone cleaned the window you have looked through so many times before, but now you notice more detail and clarity). Metal film is the next best thing to an actual wire, so why not stick with a wire wound resistor with a known track record for excellent results that easily handles the power requirements of your crossover, rather than take a chance with something else?
    By the way. I buy the Mills resistors from Parts Express for $3-4 a piece in bulk, and sort through the lot to find a close match (<1%) rather than pay Mills to do the same for $90 a piece.
    VR3 Posts: 29,399
    I use Mundorf all the time - in my experience they are a tad brighter in presentation which if you prefer that is a good thing :)
    As far as power handling and signal transfer, etc etc they are up there with Mills no problem.
  • audiocr381ve
    audiocr381ve Posts: 2,588
    I agree.
    I much prefer the transparency of the Mundorf over the Mills. The Mills has a nice sound to it too. I think it works great if you listen to a lot of blues or stuff with electric guitar.
  • Joe08867
    Joe08867 Posts: 3,919
    I think it depends on what you want to spend. If you don't mind the extra cost the Mundorf's are hard to beat.
  • quadzilla
    quadzilla Posts: 1,543
    The Mundorf MOX resistors aren't that spendy.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Phasewolf
    Yes the cost is about the same. The Mills come in both 5 watt and 12 watt and the Mundorf in 10 watt. The only issue with the Mundorf is they don't seem too have one value I need and that is the 6.2 ohm I would need to use a 6.8 or use a Mills in that spot.
    As for bright not too sure on that one as I still have the sl2000's installed and don't have the money to install Rd0-194's as of yet. :(
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
  • gimpod
    gimpod Posts: 1,793
    Make your life easy and just go with the 12 watt Mills, The Mills come in just about any value you need.
  • Phasewolf
    Yes the mills comes with just what I need and the cost is the same just thought I would ask before I went and ordered. So I should use the 12Pulse watt vs the 5 watt correct? I know stock they are 5 watt but will they fit OK on the stock boards?
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
  • gimpod
    gimpod Posts: 1,793
    Yes the 12 watt Mills should fit fine there not much bigger than the stock cement ones.
    [Shameless Plug Alert]
    Of course you could buy a set of my boards and you'd have no problem getting them to fit at all. :redface:
  • Phasewolf
    Yes I could do that but I will need too look at my money lol. I have the money as of now for boards or parts not both. Do you have any left? Drop me a pm with a price.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Polk F/X500i Rears
    Parasound HCA-3500
