SurroundBar6000 IHT - Trouble Syncing Subwoofer
Falk3r
Falk3r Posts: 2
edited January 2012 in Troubleshooting
Just unboxed the SurroundBar6000 IHT and I'm not able to get the subwoofer to sync with the bar.
The surround bar plays audio fine (optical source 1), and the green LED on the underside of the bar is blinking slowly... about 1 second on, 1 second off.
There is a green LED on the back of the subwoofer blinking at about twice that rate.
I have attempted the manual instructions a few times:
1) Power bar + sub off.
2) Power on bar.
3) Hold sync button for 3 seconds (until LED blinks green).
4) Power on sub.
5) ... wait...
They're about 5 feet apart and shouldn't be experiencing any interference in the area. Help?
Post edited by Falk3r on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited December 2011
    Have you tried powering both down, powering both back up then hold the sync button? I don't see how the bar can sync with the sub if it is off.
  • Falk3r
    Falk3r Posts: 2
    Yes, I have tried waiting until both are powered up and then holding the Sync button for 3 seconds. No avail.
    I suspect the instructions tell us to hold the Sync button on the bar (while on) and THEN turn on the sub because the sub goes through an auto-sync on power-up.
    I've got an email into the customer support group, I'll provide that feedback here.
  • dudeinaroom
    Good luck and welcome to club polk
  • superdifficult
    superdifficult Posts: 1
    edited January 2012
    I am also having this problem though my subwoofer switches from blinking green to blinking red (maybe orange, but looks red to me). I do have other WiFi devices in the immediate area, but I have changed the channel on my router (both 2.4 and 5 Ghz) and put it into a low-power mode to reduce its signal strength. I have also - with all WiFi devices on - synced the two hoping the channel hopping would find an open frequency. Nothing seems to be working...
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited January 2012
    Hello,
    Give Polk's CS a call at 1-800-377-7655 for help.
    Regards, Ken
