Claritycap ESA 630V - various values for Polk speakers
quadzilla
quadzilla Posts: 1,543
So for those that have been reading the vintage forum, you already know I had to buy 10 ea of the values I needed for my 2.3 TLs. Now the extras are up for sale. All caps are brand new, and I'm selling them at 10% off the list price. I got a larger discount, but then shipping ate up a chunk of that, so 10%. But if you want to upgrade your 2.3 TLs, and will buy a full set, I'll give an additional discount. I have enough to do 4 more sets of 2.3 TLs. In other words, 8 of each value listed. Prices are as follows:
5.8 uf 18.00
8 uf 21.00
16 uf 35.00
18 uf 40.00
27 uf 58.00
So that's 344 for a full set for a pair of 2.3 TLs, but I'll go 325 shipped if you buy a full set. And I really prefer to sell them as full sets instead of ending up with a handful of values here and there. You will almost certainly need Gimpod's boards to do this upgrade. These caps are not small. An 18 uf is about 3-4 times the size of a 20 uf Sonicap.
There's also the option, if you're not comfortable upgrading your xovers yourself, for you buy the rest of the parts, ship them and your old xovers here, and I'll send you a tested set of xovers built using these caps, no extra cost. But, again, only for 2.3 TLs.
Questions? PM me for my number. If I don't respond, I didn't get your PM.
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
  • Systems
    Systems Posts: 14,873
    edited December 2011
    How would these compare to the SC Gen. 1's?
    Testing
    Testing
    Testing
  • Systems
    Dumb question, I should have asked if you have heard both?
    Testing
    Testing
    Testing
  • quadzilla
    Not in crossovers. I replaced the gen 1 couplings caps in my amps and like the ESAs better than the gen 1s they replaced. But that's very recent, so they have barely started to break in. Really, I based the buy off the cap shoot out thread and from talking to a few members. I'll be upgrading the xovers in mine in a couple of weeks, and will know more then. The subject was also discussed in the thread I started to try to get a group buy together. http://www.polkaudio.com/forums/showthread.php?122979-Any-interest-in-a-Claritycap-group-buy. The consensus seemed to be they're anywhere from better to hella better. Dunno.... I mostly just wanted a balls out upgrade so maybe I'll quit buying new speakers every 2-3 months.
    Arm: Rega 300
  • headrott
    headrott Posts: 5,496
    I am certainly interested in a full set for some 2.3TL's, but would like to know how well they would fit on Gimpod's (Tony's) boards? Can Tony chime in on this? Or do you know how well they would fit quadzilla? I just got a set of Tony's boards and was planning on rediong the crossovers but wouldlike to know how well the Clarity caps would fit on the boards. I know Tony's boards were designed with sonicaps in mind. For $325, it seems like a reasonable upgrade for the price difference between the Sonicaps and Clarity cap ESA's. Thanks quad, please save a set for me.
    Greg
    Toolfan66 Posts: 18,082
    Wish these were for 1.2tl's I would be all over them.
    That's a serious investment you made to have these caps for your upgrade. $$$$.$$
    GLWTS..
  • quadzilla
    headrott wrote: »
    Greg
    There's a pic of a partial layout, including the largest cap in the set, here: http://www.polkaudio.com/forums/showthread.php?126065-My-2.3-TL-rebuild-so-close-it-hurts&p=1691744&viewfull=1#post1691744
    The short is they fit fine on Tony's boards.
    Arm: Rega 300
  • headrott
    Thanks. Sorry, I didn't see you posted a picture in your thread until after I posted here. No problems with getting the leads into any of the holes due to the capacitor sizes? I doesn't look like it from the pictures, but I thought I would ask.
    Greg
  • quadzilla
    easy peasy. I'll be posting pics of a completed layout in that thread this weekend. At least, I expect I'll be able to come up with the final layout by then.
    Arm: Rega 300
  • headrott
    OK, sounds good. I'll be looking forward to it. Thanks quad.
    Greg
  • gimpod
    gimpod Posts: 1,793
    quadzilla, could you ether post or PM me the physical dimensions of these caps (width x length) in inches for me. particularly the 5.8, 8, 16 as these are custom values.
    ~ Tony
  • quadzilla
    Did you need something more precise than the measurements at http://www.partsconnexion.com/capacitor_film_claritycap_esa_630.html? A quick check showed that the 8 is the same size as the 8.2. I'd expect that the rest are within a mm or 2 of the nearest value listed there.
    Arm: Rega 300
  • dorokusai
    dorokusai Posts: 25,576
    What do you have left? I'll buy them all...maybe, depends on pricing. Email direct me thru here.
    F1nut Posts: 51,817
    quadzilla wrote: »
    For the record, I sent a PM last night expressing interest in a set.
  • headrott
    No need to reply to my PM Jesse. Your reply answered my question(s) for me.:wink:
    Greg
  • quadzilla
    Just sent you a pm.
    Arm: Rega 300
  • quadzilla
    dorokusai wrote: »
    Sent you an email w/ cell number.
    Arm: Rega 300
  • quadzilla
    Headrott, your caps are shipped. Enjoy.
    Arm: Rega 300
  • headrott
    Received the caps. Thank you!
    Greg
  • quadzilla
    cool. stay tuned in the vintage speakers thread. I'm just about out of patience, and going to pull the xovers out so I can start moving the inductors to the new boards.
    Arm: Rega 300
  • quadzilla
    edited January 2012
    I've got 2 sets of these left if anyone's interested, then they're gone unless someone does another bulk buy.
    Arm: Rega 300
  • quadzilla
    edited January 2012
    And still 2 sets. The offer to rebuild your crossovers for free if you buy a set also still stands, but you'll need gimpod's boards to make it work. Otherwise, I'd have to do a point to point custom board, and that I'd have to charge at least a little bit for.
    Arm: Rega 300
  • charley95
    charley95 Posts: 908
    edited January 2012
    quadzilla wrote: »
    Damn! I have the boards, the 2.3's, but just dont have the TL's
    VR3 Posts: 29,448
    edited January 2012
    You can make them work with stock boards with some creativity...
    Thats just 3" threaded rods - you can get threaded rod in any length.. so yeah, creativity ;)
  • quadzilla
    edited January 2012
    Except that the 2.3 TLs xover is screwed to the large inductor. I guess you could get some really long #6 machine screws, but still.... and anyway, a point to point would also be an upgrade over the stock xover board.
    Arm: Rega 300
    VR3 Posts: 29,448
    edited January 2012
    No arguing that, just throwing out alternatives :)
    The ESA capacitors are incredible, IMO
  • quadzilla
    edited January 2012
    Yeah, ESA is my new minimum :) Not saying the sonicaps are bad, but they don't begin to compare to the ESA line. I'd say the ESAs are about as far above sonicaps as sonicaps are above stock.
    Arm: Rega 300
  • villock
    villock Posts: 72
    edited February 2012
    I just wanted to post that if anyone is on the fence about buying these that you will not be sorry. Rob did my crossovers and got them to me 2 weeks ago from last Friday. I know that he spent a lot of time on these and his work is top notch. The solders were perfect. So if you get these, he will mount them for free which is a great offer. Also Rob is a great guy to deal with. We talked quite a bit over the last month or so and he was always eager to answer all my questions and check in with me on how it was going. I also bought Gimpod's boards and he was also a pleasure to deal with and sent them directly to Rob for me.
    I now have well over 350 hours on these and it has exceeded my expectations by a long shot. I am absolutely floored by this upgrade and am so glad I waited to do this when I did or I would have got the Sonic caps instead of these, which I am sure are great but I absolutely love these caps and what they are doing for my speakers. I cannot explain all the nuances, superlatives as some of you but my impressions mirror Robs when he posted along the way how his were turning out. The biggest things are the much wider soundstage and the bass is outstanding now.
    So if any of you has been thinking of upgrading your crossovers, I would jump on these before they are gone, you will be floored like I am and glad you did.
    SDA SRS 2.3tls; RDO 198's, Dynamatted, Armaflexed, Gimpod Boards, Crossovers by quadzilla: Clarity ESA 630V, Mills Resistors, Track Audio Spikes, Musky's Curly Maple Caps
    CSi5, FXi5, Rythmik D15SE sub, Pro-Ject Xpression III/Ortofon MC-3 Turbo. Pro-Ject Speed Box. Pro-Ject Tube Box II
    heiney9 Posts: 25,450
    villock wrote: »
    So you've heard the Sonicaps and these are much better? It's a given they are better than stock.
  • villock
    villock Posts: 72
    No I haven't. Didn't mean to say that these are better just that I am extremely happy with these. I was going to go with the Sonicaps but saw Robs thread and his offer and thought I would give them a shot. Sorry if I offended you or anyone who has Sonicaps in their crossovers, that was not my intent.
