Psw10 membrane rip. Can it be fixed?
Amaralluis
My cat made a small rip on the membrane between the box and the speaker and I'm wondering if I can fix it (glue) or is the sub ruined? What kind of membrane was used for this sub and if I can fix it how do I do it?
Thanks for all the help.
Post edited by Amaralluis on
Post #2 wenzizi reported as spam for removalVTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
When you say membrane, are you referring to the speaker surround? If it's rubber you can fix it with super glue, which I've done. Loc-Tite makes a version that remains flexible and is great for rubber. I bought some at Lowes.
If it's foam, you can buy a kit to replace the foam which includes a new foam surround. Several companies sell these kits - Google it."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
The PSW10 surround is foam, and I recommend refoaming if there's a tear. It's much easier to do than it sounds. You can usually view instructions for the refoaming kits before you buy them.
You might be able to repair it temporarily with a dab of flexible glue until you have a chance to refoam, but the glue will likely affect performance.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
